Author Topic: Tubing  (Read 2753 times)
Tubing
« on: July 29, 2009, 17:07:12 pm »
So where do you get your tubing from? I'm currently using a raintube but i can't see anything, i'd like to have visual feedback for production, but all pvc tubes i found are shockingly expensive. and i have not found glass tubes.
how much do i have to pay and do you know where i can get transparent tubing?
Re: Tubing
« Reply #1 on: July 29, 2009, 17:37:10 pm »
Check all_acrylics at ebay USA.
The smaller thinner stuff they sell real cheap.
The larger stuff costs more because you have to buy a 72" piece.
http://stores.shop.ebay.com/All-Acrylics-LLc__W0QQ_armrsZ1
Re: Tubing
« Reply #2 on: July 29, 2009, 18:22:35 pm »
You may also want to check ot McMaster Carr.  Still expensive though.
For a  single  6"  tube test unit  I have modified an Ace Hardware Whole House Water Filter. Part Number HF-360 ACE.   You can   easily get a lot more tubes in there.   The body is Clear Acrylic. And it is machined to screw into the base.  Sealed with an O ring.
I just mounted some legs made from  aluminum flat bar ( Lowes/Home Depot)  an turned it upside down.   Then I made a round base from a  piece of PE ( Plastic Cutting Board) that fits inside the the fliter base to seal it up and to use as a flat base for the tube holder.    Glued that  in with  marine adhesive.
If you are on a budget,  this makes a good unit for testing and the cost is only $38.00 for the filter.  Compared with $200-300  for a piece of Acrylic Tubing its a good deal.
Goey
Re: Tubing
« Reply #3 on: July 29, 2009, 18:39:12 pm »
i'm from germany (eu), probably stevie or someone from that country can help more precisely? shipping + taxes are a lot from us.
i saw the water filter, will probably use it but i'd have to cut the tubes (10" case, 12" tubes ..) or i'll find something i have here ..
