A clean and green environment is a human right
Home
Help
Login
Register
Ionizationx: a clean environment is a human right!
Projects by members
Projects by members
Komtek
(Moderator: Login to see usernames) »
M.E.G. Radiant Transformer
Print
Pages:
1
2
3
Go Down
Author
Topic: M.E.G. Radiant Transformer (Read 9739 times)
Moderator
Member
Re: M.E.G. Radiant Transformer
Reply #8 on:
July 16, 2009, 03:23:19 am »
Bobbins wired!
Now need to determine magnetic north for the magnets.
Also have to make the mounting plate or stand.
I continually always do this, put 10lb's in a 1 lb package, for years!
Will I learn he ask's.
Hope I get a good result.
Logged
Hero member
Reply #9 on:
July 16, 2009, 04:27:25 am »
beautiful komtek!
Logged
Administrator
Hero member
Reply #10 on:
July 16, 2009, 09:25:30 am »
Very very nice!
Logged
Sr. member
Reply #11 on:
July 16, 2009, 12:34:55 pm »
Good luck, hope you get encouraging results
Logged
Moderator
Member
Reply #12 on:
July 18, 2009, 02:04:39 am »
Yes thank you gentleman for words of encouragement.
Well here's my MEG1 mounted and ready to test.
Will use the ElectroJolt PWM first tests and see if it can switch the magnetic flux.
Hopefully the magnets strong enough I believe its a N50 .75"x.75" cylinder.
Will give it a run this weekend but there are still some preliminary items to take care of.
Logged
50+
Reply #13 on:
July 18, 2009, 03:10:19 am »
its a;ways sp clean when you work Komtek .
I love your organized style .
Logged
Moderator
Member
Reply #14 on:
July 19, 2009, 06:45:01 am »
First tests show possibilities.
Connected those 4 primarys every way I could figure.
Need to find more small loads to connect to it.
Right now 2 small #44 indicator lamps are lightly glowing and 2 pairs of 12" long tubes are producing a very small amount of steady tiny bubbles.
I'm using 225ma 14v input = 3.15 watts.
I think if I play with more small loads it may work better.
When I put the second tube set on the incoming load current did not appear to rise.
Logged
Administrator
Hero member
Reply #15 on:
July 19, 2009, 10:46:13 am »
Hi Komtek,
No Cop 50000 yet?
Can you keep us informed on the input and output power?
I have for you some interesting pages to read, if you like.
http://www.tpub.com/neets/book8/32o.htm
In theory it does like 500mW in and 500Watt out....hmmmmmmmmm
I hope you see some results!
Logged
Print
Pages:
1
2
3
Go Up
Projects by members
Projects by members
Komtek
