Author Topic: Alternator setup v2.0.0 (looped)  (Read 8167 times)
Re: Alternator setup v2.0.0 (looped)
« Reply #16 on: July 09, 2009, 18:55:45 pm »
I'm adding a couple of  diodes to the setup, called "booster diodes".
In theory they deliver 10% more power to the WFC when any third harmonic occurs.
Webmug
« Reply #17 on: July 09, 2009, 19:25:17 pm »
@Webmug
Very nice setup!  What are you using to generate your GATE and PULSE frequencies?
« Reply #18 on: July 09, 2009, 19:56:50 pm »
Right now I'm building this improved setup.
Webmug
« Reply #19 on: July 10, 2009, 07:16:10 am »
For the same number of turns and wire thickness: DELTA gives 1.73 higher power and amp draw than STAR
DELTA Kv (RPM)  = 1.73 higher than STAR Kv while the Kt (torque) = 1.73 lower
With a STAR connection, 1.732 more turns need to be wound to get the same power (and Kv) as with DELTA
In case you're wondering: 1.73 = sqrt(3)
« Reply #20 on: July 10, 2009, 15:47:43 pm »
if you do delta then you have no neutral to connect to the negative tube? what do you do instead
« Reply #21 on: July 10, 2009, 16:05:36 pm »
looks good webmug
that looks like a good sim you got there .
« Reply #22 on: July 10, 2009, 17:11:12 pm »
Have been working the alternator for some time now.
Also did some rewinds and practiced on the small cores.
First one I like the best, cut the standard winding at the half way point around and tapped that for neutral.
That will work with Wye or Delta.
Larger alternators come with bifilar windings.
I have the diesal alternator coming and the core will be near twice as large.
For testing purposes I pull all the wiring outside the alternator and make the diode and connection terminals outside.
GM si10 alternator is 42 poles. Kevin West does a lot of neat things and on the si10 used only 36 complete wells and the last 6 are just half the winds.
Meyer used a Ford diesal alternator large core and large case 36 wells and rotor is 6 magnetic poles each side, 6 N 6 S.
The one in the picture is a small case Ford, 36 wells and poles.
WEBMUG sorry to post this in your projects, I will remove it if you want.
« Last Edit: July 20, 2009, 05:16:26 am by komtek »
