Author Topic: Alternator setup v2.0.0 (looped)  (Read 8172 times)
« on: June 09, 2009, 21:27:00 pm »
Work in progress!!! ::)
Completed upgrades:
- New motor 3 phase / 1.1kW / 50Hz / 2876rpm
- Pulley 1:2 alternator max 5752rpm
- WFC version 2 / 6 cells / 10 cm length
- Frequency regulator (for stable rpm regulation )
New tasks to preform:
- Need to find stable RPM, GATE and PULSE frequencies.
- HHO gas production measuring
- Calculating efficiency
- WFC current sensor
- Microprocessor PWM, GATE signal generator
- Booster diodes
Need some help from you guys to find resonance...
Made a screengrab of the signal over the WFC @3600rpm.
Webmug
« Last Edit: July 12, 2009, 14:53:14 pm by webmug »
Re: Alternator setup v2.0.0 (looped)
« Reply #1 on: June 09, 2009, 22:38:33 pm »
looking nice and clean, Webmug!
« Reply #2 on: June 10, 2009, 00:58:16 am »
step number 1,
buy some heavy coat 26 awg.. take the alternator and open it up. remove the stator core and winds (the outside ring) cut and remove heavy gauge copper from the core... find somthin 1.25" in dia like some pvc or somthin.. you are gonna use that to hand wind some new stators.. i would try to make like 50 winds per loop or more, there should be 3 seperate sets with i think 13 loops a each.. put those on the alternator stator core.. you will find more induction, smaller gauge (less amps) and will have way more volts then a stock alternator..
« Reply #3 on: June 10, 2009, 01:16:34 am »
dont waste any $
thatll help
« Reply #4 on: June 10, 2009, 10:43:18 am »
step number 1,
 Warp aka hydrocars aka Brian done that. So he can advise you in that, if you like.
« Reply #5 on: June 10, 2009, 13:15:42 pm »
If the blue line is the charge on he wfc, then it still sees the alternator pulses when the gate is off.
I'd first take a look at that?
« Reply #6 on: June 10, 2009, 16:39:44 pm »
Some more screenshots:
@3589Rpm on the Alternator.
First with long duty on the gate signal (the WFC fully discharged in gate off period)
Second shot with shorter duty (the WFC does not fully discharge in gate off period)
Webmug
« Reply #7 on: June 10, 2009, 17:15:24 pm »
Yes, you are right! Thanks for that... The yellow one must be the EEC driver signal. It must be the inverted gate driver signal on the FET (N-type ;D) to switch on the rotor.
Webmug
