Yikes,,, We talked about this already, and i stated that it would not work under pressure, that the explosions was less violent. It would be a Miracle for these joules to push a piston down under pressure.
Joules has been extracted in water under pressure, It was found that the higher the pressure the less violent the explosion. It was also found More joules under pressure was not 1 bit better than smaller joules under pressure, However, In a vacuum was not tested. It is only violet at room pressure, Or below pressure.
The explosion is enough to blow apart a pickle jar, or make a plastic jar jump from a table. But for the injector being under pressure, its a useless piece of contraption. "Assuming" you are talking about discharging joules in water.
Are you guy's ready for the Scarry Phenonomon, The one nobody dares to touch but me? I will probably shoot a last video and send you on your way. If my current Knowledge does not lead the way to what stan was doing he was truly a fraud. However, the phenonamon i talk about involves no electronics or electricals. It is something you guy's no nothing about at all. When i state how i want my injector made people run the other way because they do not understand how it could work.
I have a High pressure vessel to fill with hydrogen, Nobody Dares to test it but me. The explosion test alone, i simply cant get around to testing it, i simply dont have the money for it. However i may share what i "was going to do" for look sakes. That doesn't mean do it. There is one last phenonomon i will share, I have much more important things in life that takes my time away. When you remove gas from one location, a pressurized location, You'de expect a drop in pressure. If you do this properly, Can you do so without effecting the pressure? Thats where everyone gets lost.
Theres no point in me explaining it, just shoot the video and wish you the best of luck, I simply do not have the time anymore.
I will put making you guy's a video on my Todo list, as i am very busy.
