alright so to get a conversion of 12 volts 3.3 amps (40 watts) to 40,000 volts at .001 amps (40watts) we need a Z = 12,000....with R= 11,600 ohms then XL-XC= 3,073 ohms.
given information in the tech brief states that a tube size of 3 inches in height with .75 outer diameter .5 inner diameter .0625 wall thickness has a resonant frequency with the vic of around 5,000 hz. (he later also calls this resonant pulse)
so with the tube specifications and the dialetric constant of water equaling 78.54 ohms we get 9.4583E-11 farads
now here is where i am confused.....this wording is very tricky here
(http://i2.photobucket.com/albums/y2/kinesisfilms/perhertz.jpg)
what does this 2,500 discrete pulses in a 50% duty cycle per hz mean.......it isn't just a difficult way of saying 2.5khz is it?......the 50% duty cycle per hz throws me off.
electrojolt...if you happen to read this what is your take on this?
