Author Topic: New ideas and stuff  (Read 4368 times)
New ideas and stuff
« on: May 01, 2009, 02:48:48 am »
Here are my ideas . Would it be possible to have resonance with both circuit ?
I have heard from many different people that the opposing bifilar connection does have a resonance frequency and the voltage will rise up @ a certain freq , but its shadow wave will also have the same amplitude and block it .
But what if the pink coil can also resonant with the wfc/coil , perhaps this pink coil could be fed by  HV transformer ? What if also we can add a lightbulb after the diode coming from the pink coil , seems like it can be an EEC as well ... ??
Seems like it could be pretty flexible setup and an ez add-on to the jolt circuit  , some photo-transistor or w/e ... if we have a solid diode , a good 20$ diode .
We have to think how to "move" the water molecule ... We need to evolve our thinking .
Alsso , can somebody answer me this , how will these magnetic fluxes be ing when they are coming from 2 choke wires to cell , from this angle . I am not sure of this .
« Last Edit: May 01, 2009, 04:04:59 am by Dankie »
Re: New ideas and stuff
« Reply #1 on: May 04, 2009, 20:49:10 pm »
bump
« Reply #2 on: August 08, 2009, 00:44:22 am »
« Reply #3 on: August 08, 2009, 05:21:46 am »
Thane Heines is quite the engineer .
I should get that current translator to scope thing , really neat toy to see the current appearing as voltage on a scope .
« Reply #4 on: August 08, 2009, 08:33:46 am »
bump
haha, Better be glad I like you! For now, anyways
« Reply #5 on: August 08, 2009, 12:33:59 pm »
use a common 1Ohm resistor. and measure the voltage between. it's the same as current.
