Author Topic: Alternator setup (looped)  (Read 3288 times)
« on: April 27, 2009, 20:47:28 pm »
Hi everyone,
I like to share the looped alternator setup which is a work in progress.
See my other (basic) alternator topic “Alternator setup” for construction details.
I have a first setup running looping the alternator.
See video for impression of the loop.
In this video I will start the motor, then start 9V/0,5Amps DC on the rotor.
Then I wait for the WFC for gas bubbles and switch the loop in place then the external power supply only drives the Lawton circuit.
Video:
http://www.ionizationx.com/index.php?action=dlattach;topic=1013.0;attach=3833
When measuring over the WFC without the loop I get about 4,5V pulsed but after switching on the loop the Voltage rises to about 68Volt (see scope screenshot)
Also the motor is running on 160Volts/1.9Amps. (300Watts)
I think that resonance is not yet established and also no harmonics due to the low RPMS.
Below screenshot shows the used schematic (left the Lawton circuit right the looping and kick-start switch, currently only one tube is used.
« Last Edit: July 09, 2009, 19:26:47 pm by webmug »
Re: Alternator setup (looped)
« Reply #1 on: April 27, 2009, 21:07:09 pm »
Just woken and mind is busy, but second timer must use .01 cap and the first a green cap, forgot that value.
Looking goooood! and yes, you have to have the proper rpm in order to hit harmonics, and the loop all together.
i'll keep an eye in this thread
« Reply #2 on: April 27, 2009, 22:20:12 pm »
Way to go, Webmug!
best regards
« Reply #3 on: April 27, 2009, 23:10:05 pm »
I never had any luck with the kickstart, get it to work without one.
Also, i'm not sure how just 1 tube will effect it from 6 tubes, its possible it will he difficult to regulate when you get going. You must hit 3k or 3.5 K before the loop comes alive. Have mercy on your fet until you figure this out, i recommended the FQA30N40 for this.
Watch the last video i sent you, get that down first.
« Reply #4 on: April 28, 2009, 15:58:33 pm »
Hi Brian Coats, Stevie,
Thanks for the reply!
I tested with 6 parallel tubes, with the loop in place I’m reading 8 Volts over the WFC.
Without resonance/harmonics the loop regulation is not difficult, one freq setting is sufficient.
I’m curious how it is going to behave when these two effects come into play.
« Reply #5 on: May 05, 2009, 14:10:14 pm »
Hi,
Little update here on my looped alternator setup.
Still waiting for more parts. Got my new electrical motor  to run the alternator at 3000+ RPMS.  Just waiting for a pulley.
« Last Edit: June 10, 2009, 17:55:42 pm by webmug »
