Stanley Meyer => Stanley Meyer => Topic started by: outlawstc on April 28, 2009, 01:46:14 am
Title: the hutchinson effect
Post by: Login to see usernames on April 28, 2009, 01:46:14 am
Title: Re: the hutchinson effect
Post by: Login to see usernames on April 28, 2009, 02:04:43 am
Extremely mysterious ...
Is this related to John Kanzius I wonder ...
Post by: Login to see usernames on April 28, 2009, 02:38:15 am
its related to what we are doing.. his magic rocks he makes have a mix of crystals and common minerals and metal.. they are just absorbing power from earths positive vacuum state and negative pressure state electromagnetic fields.. you see a is like a wind vienexcept its wind is electromagnetic current.
Post by: Login to see usernames on April 28, 2009, 02:40:25 am
he also mentions it involves the Casimir effect..
http://en.wikipedia.org/wiki/Kashmir_effect
Post by: Login to see usernames on April 28, 2009, 03:03:57 am
Post by: Login to see usernames on April 28, 2009, 03:14:36 am
If only we know how hustchison effect worked . Theres so much mystery surrounding this , shit is really really really subtil ...
Its probably not "high voltage throught air dielectric" ...
What is it then ...
Post by: Login to see usernames on April 28, 2009, 03:33:18 am
its probably not "high voltage throught air dielectric" ..
thats where your wrong its like a water coming out of a hose it can be amplified more pressure more chance for distance and penitration.... kinda like how a worm hole in space can exist.. its is surround by mix infinity vacuums as well
Post by: Login to see usernames on April 28, 2009, 11:32:30 am
This is nice. I read this wikipedia on Casimir and its worths a try, is it. Electrojolt is starting now something on this and i will try some tests on this. 2 opposing waves..... It might be RF or simple electrical waves.....who knows. Just do some testing people!
br Steve
Post by: Login to see usernames on April 28, 2009, 23:04:48 pm
Post by: Login to see usernames on April 29, 2009, 01:09:39 am
Post by: Login to see usernames on April 29, 2009, 04:24:14 am
Pretty interresting outlaw video outlaw , the twin vortex video ...
Dam , that stuff is everywhere . And I'll be damned is Meyers tech doesnt follow this process ...
Post by: Login to see usernames on April 29, 2009, 11:46:47 am
Very interesting but an inward swirling gravity wave should pull matter in a bent matter I guess
Post by: Login to see usernames on April 29, 2009, 12:04:03 pm
look up victor shauberger he has alot of great info about the flow of energy.. he says water is a living element.. it is living at 72 degrees which is its most condensed point ... he also explains how water can kill bacteria on it own,,, he says if you put water in a cyclone it is pulling oxygen into the water in the eye... and it starts to oxidize all the bacteria.. he also says that making water flow a certain way will make it return to 72 degrees even if outside tempatures is 100 degrees... look him up
Post by: Login to see usernames on April 29, 2009, 12:50:36 pm
br Steve
Casimir force, could it relate to the snapping action / rubber banding effect? Stretching the electrons from the nucleus like a rubberband, and then letting it go (snapping action), electron bounces closer to the nucleus compared to steady state, and the situation of Casimir occurs.
Post by: Login to see usernames on April 29, 2009, 12:55:59 pm
this is how i relate life to the nature of electric... to practice is to cycle (resonate the idea or movment) for practice to achieve gains it has oppositions clairty and distortion.. it is the spirits job to apply intuition and search for the clarity to become a master.. but the truth is everythings clarity goes to infinity and you can never reach the top. but you can travel towards it or away its up to you and all it takes is time.
i would say cashmier effect is like the rubber band.. we understand the resonance of electric circuits.. now start thinking of the resonance of mass
Post by: Login to see usernames on April 29, 2009, 12:59:54 pm
Post by: Login to see usernames on April 30, 2009, 03:17:16 am
victor shauberger video he speaks of the original motion.. i suggest looking into that and incorperating that idea into the vic transformer... the coil may work as is now but i am betting the primary is wound wrong... i think i know how its producing its power... you need to wind the primary longitudinal.. it doesnt look possible to wind perpendicular to the choke and secondary because it isnt.. i think stan made a special cuff that the primary was wrapped around.. understand longitude.. you know where north and south is on the transformer.. so you know a longitudinal line travels from north to south... the chokes and secondary are wound east to west... when you wind longitudinal it is bidirectional because when it's wound around the cuff each fold on a 2-d plane is changing direction in a north in south relationship.. now think about what actions are gonna happen on the core. you have slowed down time kinda... when winding north to south the primary only makes 1 cycle around the core but has a shit load of inductance... i beleive the vic itself creates the original motion with electromagnetic energy... non harmonic (loud, explosive, amps) harmonic (quiet, implosive, voltage) non harmonic power is the energy traveling from cyclone eye wall out the top... harmonic energy flows opposite.. stans secondarys colapsing i think act in a harmonic manner.. when primary is pulsed the secondarys colapsing i think are like the hamonic transfer in a cylone..
Post by: Login to see usernames on July 30, 2009, 05:04:26 am
Post by: Login to see usernames on July 30, 2009, 21:16:07 pm
interresting ....lol
Post by: Login to see usernames on July 30, 2009, 21:17:48 pm
