Author Topic: Has anyone played with using 3phase ESC for brushless motors???  (Read 637 times)
Re: Has anyone played with using 3phase ESC for brushless motors???
« Reply #8 on: September 29, 2021, 06:07:56 am »
Seems this set up is really touchy and only works with this wiring set up.
2 outside leads add a positive flowing to one and negative flowing to the other.
Center tap is neutral.
Hook up Cathode to center tube and
Anode to the water bath
(Near future I’m attaching a cylindrical piece of Titanium foil around the outside of the tubes to the water bath lead this will be oxygen collecting)
« Reply #9 on: September 30, 2021, 08:25:00 am »
Water bath means the housing ? Or just a wire in the water?
« Reply #10 on: September 30, 2021, 09:38:25 am »
Hi Steve
Recently I used a piece of SS wire for the connection to the water bath. I just switched to a SS straw from the kitchen section.
I’m hoping I can add a liner of of titanium foil to the inside of cell container.
I’m looking to try cutting the titanium foil to a size that will tune the tiny bubbles into larger ones possibly using different surface space ratio to attract more H2 over O2.
