Author Topic: Understanding And Creating  (Read 24191 times)
Re: Understanding And Creating
« Reply #32 on: January 18, 2008, 09:29:54 am »
Wouter, Hydro,
The 12 diode setup is NOT good.
I get more amps in the old 6 pack setup.
Voltage is the same.
Case closed.
ps
some diodes are set wrong in that schematic
    • WaterfuelForAll
« Reply #33 on: January 18, 2008, 20:47:56 pm »
Hydro, Stevie
We are all friends with the same goal and we are all doing research
so it's just natural that we might differ from each other from time to time,
 but in the end, two heads is better than one!
Hydro, could you elaborate a bit on the results of tests that you have performed on the
setup as per the schematic posted at http://ionizationx.com/index.php?topic=140.0 ?
I would love to give it a try, if you are confident that it works just as in the schematic.
(You do not perhaps have a link to a video that I can watch in this regard?)
Stevie, could there be a difference between your setup and Hydro's which could explain why
 you do not get the same good results? What is wrong with the diodes?
Thank you both for answering my questions!
Wouter
« Reply #34 on: January 18, 2008, 21:13:52 pm »
Wouter,
I think that you think that Hydro and me are using different setups?
That is not the case. We have similair self sustaining alternator setups.
I also use a FET for controlling the voltage on the rotor. With the same electronic circuit....
My comment about the 12 diodes was on the aurora schematic.
Hydro said to me that it was a waist of time....thats why he wrote: no command....(read as: nahahahahaha, I told you  :D)
Yes, I also think that more heads are better then 1.
Question:
Why do you think that my results are not good? What did I mis here?
Have you seen my youtube vids?
keithturtle
« Reply #35 on: January 19, 2008, 03:46:38 am »
Hydro, Stevie
You are absolutely right!
<insipid grin>
Turtle
    • WaterfuelForAll
« Reply #36 on: January 19, 2008, 18:00:23 pm »
Question:
Sorry, a misunderstading!  ;)
I thought you meant that you tried Hydros' setup and it did not produce good results with you. My
mistake...
Is the selfsustaining setup you are using the same one as posted at
I would love to watch your videos, can you maybe post a link?
Wouter
« Last Edit: January 19, 2008, 18:04:25 pm by passion1 »
« Reply #37 on: January 19, 2008, 20:45:09 pm »
i will have a new video, but it will be some time before i can. just hang in there...
« Reply #38 on: January 20, 2008, 12:50:22 pm »
Question:
mistake...
Wouter
Wouter,
on the top of our forum, on the right is my first vid.
On the left you see the vid of Hydro.
I ll guess that Hydro's vid will be changed very soon with a new one.
In this topic you see all 4  of my WFC vids
http://ionizationx.com/index.php?topic=85.30
You can also search on stevie1001h2 on youtube.
About the circuit, the answer is yes. I use the same.
The point is that it doesnt matter what kind of switching circuit you use.
Any circuit will do, even the famous Dave Lawton...ONLY you have to use the wiring and the fet setup as drawd.
Have fun!
« Last Edit: January 20, 2008, 12:53:51 pm by stevie1001 »
    • WaterfuelForAll
« Reply #39 on: January 20, 2008, 15:49:06 pm »
Stevie
Your videos are very impressive!
But on 26 December you poseted that the
Second test with alternator  gave a gasoutput 0.32 liter per minute.
Using a series cell with close to Faraday production would give 1 LPM @ roughly 15 amps @ 13.8V.
Thus the gas production with the alternator seems to be way less than Faraday, yet you say the setup is self sustaining?
What am I missing?
Wouter
