Alternative Energy => Low Cost Devices => Topic started by: Logic on September 07, 2009, 16:16:03 pm
http://www.somender-singh.com/ (http://www.somender-singh.com/)
I cut my own version of these grooves im my cylinder head when I had it off due to a leaky gasket.
I got lower engine temperatures and an increase in power and torque. (especially at low revs)
This translates into lower fuel consumption when not using the extra oomph.
These claims are subjective of-course, but a quick search of forums will show that others are getting the same results.
Especially in 'hot' modded engines.
This is a great fuel saving mod and the cost is Zero!
it is interesting but , an increase in power and torque is due to enlarging the volume of the cylinder.
what kind of fuel difference you got what is your car year model modifications you ve done on it ?
it is a big job to do such a thing if your car is not due to a head gasket (we are talking fuel economies) .
post some of your results .
The idea of creating a lot of turbulence due to the groove in the cylinder head is great for a perfect mix of fuel in the engine .
My results are subjective, as I said Najman. :)
You are correct in that no one is going to pull their cylinder head just to try this.
My head needed to be skimmed before replacing the gasget.
I also had the valves reground and lapped.
I also did a little port matching at the port - seat interface.
You will learn that I research my pet interests very well.
I decided to give it a try after reading pages like this:
http://forums.turbobricks.com/showthread.php?t=66779&highlight=singh
I believe this should work in a similar way to using H or plasm sparks:
The mixture burns faster and you can adjust that burn to take place at the optimal crank angle.
More of the mixture is burned rather than wasted.
I figured that if it did not work/help I would have lost nothing, as long as I made sure not to leave any sharp points or edges where pre ignition could happen.
This is under "Low Cost Devices" :)
Google will give you plenty of info on this.
Hi all,
I install the gadgetman groove. Check out http://throttlebodymod.com
It's cool stuff too. the only downside is the 3800 or 3.8litre engine. I am helping to solve problems here with Ron who is in the process of moving. Akin
Hi all,
Hi Akin,
Can you tell us a little bit more on what that device is?
regards
Hi all,
Hi Akin,
hello Steve
i hav been following the gadget man since last year the guy seems sincere it says on his website money back if it wil not work .
the groove is done just after the throttle body (imagine Ventury but reverse) creating a donat chap in the air upon what i understood from his explanation .
i want to send him my throtle body but no money to do that mode i have to instal my hho system on my Land rover .
regards
Steve and Group,
It is a venturi groove installed on the intake side of the carb or throttle body. For more info search for Gadgetman Groove and check out all links for that. As stated above it causes the engine to respond with gas savings and more power. My savings was only 25 % (8 - 10 city---12 - 16 highway) the throttle has more power. I used to have slow starting in the cold weather, now the old Dodge starts right up! Akin
Can you post pictures of the throttle body mod? I cannot find any after googling. I find testimonials but no pictures of the groove in the throttle body.
Somender Singh Grooves are about creating more turbulance in and around the spark-plug gap, as well as an ignition path into the squish area.
Gadgetmen Grooves are about creating turbulance near the butterfly valve in a throttle body or carburator.
Although interesting, as the principle behind the two different types of grooves is so different; I feel that the subject of Gadgetmen Grooves requires its own thread?
The Gadetman Grooves are interesting. I think it's not so much about creating more turbulence as it is developing horizontal vortexes of air before the intake manifold. It's very simply a groove in the throttle body of some engines along the butterfly valve plate. It would warrant a separate thread. It has pros and cons.
Regards,
Andy
