Author Topic: Ultrasonic Nebulizer Array 3000mL per hour Cold Fog Generator WATER BURNS  (Read 128112 times)
0 Members and 317 Guests are viewing this topic.
Hi FI,
Thanks for sharing this part of the water technology!
You keep on going with it. I like that.
I think you are aware of the steam to hydrogen technology.
My two cents with waterdrops is to use one drop of water with every explosion in the cylinder.
That drop must expand into gas.
with a ratio of 1 to 1800, the piston must move downward.
regards
Thank you Steve for the info.
Here is a drawing of the next fogger setup I'm working on.
Here's a link to a excellent tool for everyone. Paired with a Zero Ohm stable audio amplifier you can start testing switch mode power supply transformers for the one that works best for you.
PWM Generator
The PWM Generator can generate Pulse Width Modulation signals in real time.
http://www.esseraudio.com/en/pwm-generator.html
I am impressed, FI3..
Glad you are sticking to this.
I have noticed those UV lamps for ponds as well....
Maybe you can do a small test with those lamps just on HHO gas?
Just see if it gives some reaction?
Just use enough HHO to run a burner. Lamps on and lamps off.... See if notice any difference...
Hi Steve,
 I have tried UV-C lighting on HHO gas sometime ago. I did not see a difference in burn of the flame. Which would make sense because the work of breaking the water into a fuel has already been done. The UV-C light is to assist in the breakdown of water into fuel. This is why Meyers called it molecular disassociation of the water molecule into energy.
I'm referencing a part from a web page posted earlier...
http://www.hydrodrive.co.in/ENERGISING%20WATER%20MOLECULAR%20COMPOSITIONS.htm
 Certain energy transfer to water molecules can excite or energize the O—H stretch vibrational modes of the hydrogen bonds. There exists various excited states of H2O and the diffusion, relaxation and reorientation from the excited (or energized) states of the O—H stretch vibration will lead to a change of the hydrogen bond dynamics of liquid water.                         The terms “excite”, “activate”, “energize”, “irradiate” or “stimulate” interchangeably refer to a process that adds a discrete amount of energy (“excitation energy”) to a system such as atom(s) and molecule(s), which results in a transition of the system from a baseline energy state (“ground state”) to one of higher energy state (“excited state”). For example, excited electronic or vibrational states usually occur following the absorption of radiation of certain frequency (e.g., that corresponds to the energy differentials between the ground state and the excited state). The excited state is typically short-lived and can return to the ground state through processes such as radiative emission (fluorescence), thermal emission (heat) and by reaction.
                        The vibrational dynamics of water in the proximity of a surface (i.e., interfacial water) demonstrate different behaviors depending on the phase/states of the water, i.e., whether the water is in liquid or gaseous phases. For liquid water, the vibrational dynamic also differs depending on whether the liquid water is bulk or confined.
Whatever our resources of primary energy may be in the future, we must, to be rational, obtain it without consumption of any material" Nikola Tesla
            Here is some of my research I have shared yet. The ignition system is also the power supply to these devices. It is a magnetic flux compression device.
THE FUNDEMENTALS NEEDED
Marko Rodin has discovered the source of the non-decaying spin of the electron. Although scientists know that all electrons in the universe spin, they have never discovered the source of this spin. Rodin has. He has discovered the underpinning geometry of the universe, the fabric of time itself. He has done this by reducing all higher mathematics – calculus, geometry, scalar math – to discrete-number mathematics.
http://vortexmath.webs.com/
                                  Edward LEEDSKALNIN
                                       Magnetic Current
                                                 http://www.rexresearch.com/leedskal/leedskal.htm
                                             THE  ELECTRON  PHASE  SHIFT
                                   http://glafreniere.com/sa_phaseshift.htm
               (http://glafreniere.com/images/huygens00.gif)
                                               FLUX COMPRESSION GENERATOR
                             http://reactor1967.fortunecity.com/freenergy.html
High Energy Free Energy Generator - Fcg's being used for free energy. The USA military use this to power its high energy weapons. (Status classified by the USA)
(http://reactor1967.fortunecity.com/ps.jpg)
MAGNETIC PULSE COMPRESSION (MPC)
Magnetic pulse compression utilizes reactors in conjunction with capacitors to shape input pulses into narrow output pulses of much higher current . MPC, therefore, allows the designer to use less expensive input switches with lower current ratings. MPC can also extend the lifetime of the input switch. Advanced MPC devices - capable of generating power levels of multi-terawatts in tens of nanoseconds - have been realized utilizing Metglas® cores.
                                                          http://www.metglas.com/products/page5_1_3.htm
This product may require licensing for export outside the United States:
Please visit the U.S. Dept of Commerce website to understand the necessary requirements. ( http://www.bis.doc.gov/licensing/index.htm#factsheets )
Metglas®, Inc. requests that the applications and approval accompany any request for samples, quotations, or purchase orders.
         Everything is relative  And never take anything too serious or too lightly.... While to go forward you really are going backwards..... Nothing is impossible, it is only wheather or or not it is probable in my time....
« Last Edit: August 05, 2011, 16:53:43 pm by fastimports3 »
Here is update on fogger unit I'm working on. Next part is to add the particle charging effects.
