Electronics > High Voltage
NEW RESONANCE CIRCUIT
(1/5) > >>
Steve:
If resonance was involved in the Stan Meyer setups, it should have looked like this.
(Thanks to Richy Burnett, http://www.richieburnett.co.uk/dcreschg.html )
The tank circuit is charging the capacitor to twice the voltage as the powersupply is providing.
Then you close the circuit to discharge the cap into the wfc.
Maybe the circuit needs the be cut off  from the powersupply when the switch is on to the WFC......any thought from you outhere?
Hopes this helps
hydropower:
Damn...we should have known that one tonight if i hadnt burnt a transistor    :D
Hydropower
Steve:
The idea on this circuit is: AMPS
Almost no amps for charging, but lots of amps from DISCHARGING
Example:
I charge a cap to 600V. (I use a 300V powersupply and the circuit uses resonance to get it up to 600V)
The resistance of the WFC tubecell of my has a resistance of less then 1 ohm.....
For calculation, lets take 1 ohm as a number.
When i discharge a 600V cap with a 1 ohm resistor, how much amps do you think will flow?
Yes, 600 amps for a brief moment.....
Does that make you all think?
hydropower:
It is very interesting...thank you stevie1001
Hydropower
Fiditti:
Thanks Stevie,
Very exciting circuit indeed.  Those are some high amps.  The potential for very high gas output is possible with this setup.
[#] Next page
