My cell is styled after Karebills. It's a six cell. Three 316L tubes each, 1" x 10", 3/4" x 9 1/2", And 1/2" x 12". With a 1mm gap between each of the tubes. The over all size of the cell is 2" x 12" x 16". It will be supplied water by a live well pump, as suggested.
Spike
Flagpole
Your gap is to wide, Unless your cell is going to be 24" tall or more. Try to get at least .065 wall thickness, Or .095 if you can. You will get better production.
Spike
Been working all week, But I'm off for the weekend ;D
Spike
Flaghole, the cell your about to build is pretty close to the one I built
execpt my mesure were slightly higher.
My wall thickness is 1/8 and 36" long with 8" dia.
Tubes are 1.5" and 1.25" at .064 thickness 27" long.
I used plumber gasket for spacers.
My problem is when connected in // the cell draws around 100 amps no pwm. straight DC -- I also get a lot of sluge :(
when connected in series, .8 amp but no production :(
If you are formulating cells for resonance I would like to recommend not to forget the fibonacci number (Golden measure, golden rule, or whatever you wish to call it).
1 X 1.618
If the width is 1' then the length is 1.618' or some derivative of these two.
This number appears in nature and man-made things very often.
Hey! here my desing im working on. With around 2 teaspoon of baking soda im getting around 14 amp at 12V with two of those device in serie. Planinng to get up to 6 if thing goes well :D. It produce a very good amount of HH but not sure how much... maybe 1L/min (for 2 units). Hope u like. If some of u are interested i can take some pictures of it. Oh i forget to say that it separate the hydrogen from the oxygen ::) ... in the pictures all the plates to the right are connected togetter and same for those on left
