Projects by members => Introduction => Topic started by: electrotek on June 25, 2013, 02:54:19 am
Title: A long time builder says hello
Post by: Login to see usernames on June 25, 2013, 02:54:19 am
I'd like to say hello to the members of this forum - I'm Electrotek. I've been in the field of Alt-Energy since 1961 (52 years). Since I made it onto the Internet at the turn of the Millenium, I've been able to share some of my discoveries, and understanding, as well as some of the things I've been shown by others. I always give credit where credit is due, but I have made some significant advances on my own.
One area I'm particularilly fond of is Scalar Art. This comes easy for me, since it's intuitive, almost to the point of being some kind of ancestral memory. Here's a picture of a Scalar Interferonomy effect I've demonstrated:
This shouldn't be confused with the so-called Tesla Howitzer, since my effect is very short range. People who are familiar with the Caduceus will recognize that my effect is genuine. In operation, that device has an energy spot on the side of the top ball electrode. When the Caduceus is slowly rotated to the right, the position of the energy spot moves to the left. This is the same as my effect: when my tube is rotated slightly to the right, the position of the projected image moves to the left.
I've also reverse engineered Ed Gray's Electrical Conversion Tube, on my workbench. Along the way, I discovered what he meant by "splitting the positive". So I've been able to demonstrate visible Longitudinal Energy, in the form of electrical sparks. I've documented a lot of this research at the Heretical Builders forum:
Here's my video showing a large volume Plasmoid discharge, using a mini particle accelerator:
This video is important because it shows how an electromagnet can repel a piece of steel, with quite a bit of force. When I include a small amount of water in the discharge, the fireball is bigger, with a deep red color.
Besides these things, I'm also an expert in the field of Inertial Propulsion (active since 1965). Here's my video which shows "extraordinary proof" that IP is possible. (Quoting Carl Sagan.) My machine moves straight up into the air, then, when there's nothing to push off against, it generates a thrust impulse which causes it to move forwards as it comes down. As far as I know, no one else has shown a "downwards hop".
I've also conducted experiments in many other areas. But I joined this forum in honor of the upcoming Stan Meyer Day, thinking that I might provide something which will help advance efforts to reclaim his technology. On the side, I'm also working on Meyer's water rocket, which will only require about a gallon of water to reach orbit.
Jerry Volland http://interplanetaryexpress.com
Title: Re: A long time builder says hello
Post by: Login to see usernames on June 25, 2013, 14:07:42 pm
Hi Electrotek,
Welcome to Ionizationx! With Stan Meyer to the moon sounds like a good idea to me ;)
Feel free to have a projectsection for your own, if you like.
Best regards Steve
Post by: Login to see usernames on June 25, 2013, 17:13:08 pm
Hi Steve,
Thank you for the welcome message.
Yes, a Water Rocket to the moon is an excellent idea. Manned space exploration is much more appealing than sending out robotic missions. I want to see the STARS when I'm out there. And it will be to Stan Meyer's credit. His various patents include *almost* all of the necessary elements. But, as he said, some of the information must be kept secret. I just watched The Avengers on Netflix, and the most memorable line was with the advent of a compact, high performance Independently Derived Power Source "the planet will be ready for a higher level of war". There's still too much political unrest to be publishing plans for a new and improved rocket motor.
I'm using an LC circuit which produces an ionizing radiation. Most of what I might post would fit under existing boards, and I really don't have time to start a blog type presentation. However, it might be nice to have a "Stan Meyer Day" board where new ideas can be posted.
Best Regards to you.
Jerry
Post by: Login to see usernames on June 26, 2013, 12:14:51 pm
Jerry
Hi jerry, With LC circuit that produces ionization radiation you mean an air purifier? Something with HV and needles and so?
Post by: Login to see usernames on June 27, 2013, 18:53:54 pm
I'm actually getting ionization on the atomic level. When I discharge the circuit, the spectral colors of the atoms which are present will show up in the spark. Here are some examples of the colors:
copper - green tin - blue carbon - yellow water - orange methane (Sabatier) - red thorium - dark blue
The circuit produces a complex waveform containing bidirectional potentials consisting of emf from the capacitor and cemf from the coil. Nikola Tesla referred to this waveform as 'stationary waves'. Modern day engineers use the term 'standing waves' for the bidirectional energy, which is an unfortunate misnomer. Dr. Tesla used this term when discussing longitudinal waves, which comprise two out phased waves moving in the same direction. To simplify the matter, I use 'biphasic' for bidirectional potentials and 'split phase' for unidirectional, longitudinal potentials. Here's a picture of a split phase longitudinal spark which shows two potentials spiraling around each other, in the same direction (ie, standing waves):
The longitudinal energy pumps charge carriers and can be used to separate electrons from ions.
Interesting stuff, Jerry. So, first you put the charge from the capacitor thru a spark and then the charge of a coil? Or are both discharged in the same direction?
And that in some kind of lc resonance circuit?
Post by: Login to see usernames on June 27, 2013, 23:32:50 pm
Jerry,
Tell me a bit more about your explanation of standing waves... Herman Anderson was talking about this, but i could not understand what he meant.
What do you want to achieve with your setup with the acc plate spark?
I appreciate your openess and technicall vision :-)
Post by: Login to see usernames on June 28, 2013, 04:28:44 am
Your work sounds very interesting ...looking forward to having time to look deeper 8)
Post by: Login to see usernames on June 29, 2013, 09:25:52 am
My current build with the gradient plate will have an enclosed arc chamber, with three inlet ports, one for steam, one for externally produced HHO, and one for air, including CO2. I really like Jon Able's injector diagram, and I think a single port for each input will be adequate in the beginning. I previously had a plate with an enclosed arc which allowed me to add liquid water, but this didn't always work. h2opower pointed out that liquid water has a capacitance which has to be just right. So I'm going to try using steam, and see what happens.
And I'm building an HHO unit which uses stainless steel sauce cups, like I saw on YouTube. If this works, I'll start a thread on the Members' projects board, and take it from there.
Jerry
Hi Jerry,
How hot you think, does your sparks get? Is it hotter then a normal spark?
Post by: Login to see usernames on June 29, 2013, 21:04:41 pm
I'm glad I joined this forum. I hadn't previously heard of Herman Anderson and it's obvious he was on to something important. His CV is incredible - all the way from the first satellite to Star Wars, with a Water Car along the way. It seems to me that his usage of 70,000 Volts was a requirement for getting instant electrolysis, since I've gotten x-rays at a tenth of this voltage. Presumably, the protium fusion will also operate at the lower voltage.
When he mentioned standing waves, it was the same thing I've got, since he was also using voltage, rather than em waves. My first answer to your question about these waves was a little unfocused. What I described with my first thoughts, the rising and falling peaks, was related to the waves along the outside of a Tesla Coil, with a parallel grounded conductor. When it comes to standing waves in the form of sparks, two parallel sparks spiral around each other as they travel. Subsequent current behind the leading edge travels along the exact same path as that which passed before it. So, as long as current continues to flow, all waves along the path look like they're standing still. Any given portion of the spark trail remains constant and the envelope never moves length wise. It looks like the waves in the spark trail are standing still, and that's why I call them standing waves.
Converting hydrogen into deuterium works through a process called electron catalysis. When an electron comes between two protons, the electron shields the positive charges and completely eliminates the Coulomb Barier. This allows the protons to come together at a low energy level, and in the process one of the protons absorbes the electron, turning into a neutron. The result is that two hydrogen atoms become one deuterium atom.
You also asked:
The sparks are pretty hot, since they'll melt the end of a copper wire, at a power level of one kW. However, this is because I'm not using a high speed interrupter. Tesla experimented with this same effect and reported that the sparks are completely cool when chopped at a rate of one hundredth micro second.
Jerry
I am speechless, Jerry. That does not happen often anymore.. :) Now i must try to consume what you wrote. 8) Thanks Electron catalysis is a proces i never heard from. Not that that means anything, of course. So, you seen the video interview with Herman?
About the 70kv sparks, i can tell you that i had those going thru my cell. The sparks where of course outside the cell, but the 70kv went thru it. No results to mention. But i also didnt measure any x rays in the proces. This is probably also why i didnt see any effects.
Kevin and me are probably the only persons here, trying to solve the Herman puzzle. What could you suggest, to get X rays in the setup of Herman?
Post by: Login to see usernames on June 30, 2013, 20:35:31 pm
Hi Everyone,
At the end of this thread, I'll mention that I do have a relevant patent, which came out in 1981. (#4,260,933 - Selective Frequency Optical Generator.) In this patent, I mention photo disscociation of water. This is a longitudinal process and requires something called a resmod tuning element, which, for water, would have an incredibly small dimension. I've been keeping an eye on manufacturing processes which could produce such a tiny wire with a ball on the end of it, and there is one company which is now offering a 3D printer which operates on this scale. However, now that I know more about the HHO field, I'm sure there are better ways to do it, since my patented device would basically just be energy in equals energy out.
