Title: Re: Ambient airgasprocessor setup
Post by: Login to see usernames on March 02, 2010, 01:36:55 am
I am designing my own ion wind generator .
My circuit will incorporate a flyback transformer that I make myself with some stainless steel bobbin I have I will cut the middle an d wrap a primary on top and see what happens .
I will then allow the gas to flow in the middle of wheree should be a core and feed back the HV wire in itself .
If It works I have also a deisng , a succession of +-+-+- and finished by - in connected in series in the tube but parallel to eachother pareallel with eachother where the optimum frequency related to gap space is found for maximum acceleration and current is kept rolling in the same direction with a freewheel diode
Post by: Login to see usernames on March 02, 2010, 07:54:55 am
Excellent ideas Dankie! I was reviewing the info Steve posted and I noticed the intake ionizing system utilized the LED arrays. This is not a big deal other than finding who sells these. Any Ideas?
Post by: Login to see usernames on March 02, 2010, 14:26:05 pm
Im glad you like the idea , it is more a logical thing , I see the core I say hey , theres a bunch of magnetic lines in the middle , why not use this as a gas processor and insert some HV .
Post by: Login to see usernames on March 03, 2012, 14:08:20 pm
Meyer gas processor creates positive ions not negative ions. Gas processor is the key of meyer process. Attached an extract from meyer patents.. I'm glad to annunce that in the next days I present new water gas stone stove using meyer process inside.
