Stanley Meyer > Stan Meyers system 1
Open letter to P. Lindemann
<< < (11/12) > >>
tutanka:
--- Quote from: Donaldwfc on October 23, 2011, 03:40:19 am ---Stan did not use UV light. The reason why he did not use UV light is because it would exceed the work function of the SS and create a photoelectric current inside the Hydrogen Gas Gun. UV light would pluck electrons off of the plates and send them into the gas cavity, which is exactly counter to amp restriction process that is required to ionize the combustible gas atoms.
--- End quote ---
That isn't UV???
tutanka:
--- Quote from: Donaldwfc on October 23, 2011, 03:42:38 am ---Nitrous Oxide is discussed in the Exhaust Reclaimer Technology in the Tech Breif, it can be broken down and completely eliminated. It is not desired, and yet even without eliminating it, it is minimal as a byproduct anyway. Listen to him talk about it in his various lectures.
--- End quote ---
Sorry but you forget if you think that only hydrogen produced from WFC run an engine 100%.  Nitrous oxide is formed from oxygen of water during the process and is, with ammonia, the other main component for reach right green fuel. Document attached is extracted from scientific analisys.
tutanka:
--- Quote from: Donaldwfc on October 23, 2011, 03:37:28 am ---Everything I said was correct. You have some more learning to do.
--- End quote ---
Sorry .. in part is correct.. however explain chemically with formula what is your water fuel. If you know for you is simple write that.. My formula is 8N2+6HHO+Hv=4NH3+6N2O.. yours??
Donaldwfc:
--- Quote from: tutanka on October 23, 2011, 08:30:22 am ---
--- End quote ---
That isn't UV???
--- End quote ---
If you list all of Stan's technologies, UV light is not required for any of them. That is talking about recycling water AFTER it's been used. This is not required, it's just another approach instead of letting the water go out the exhaust pipe and then into the atmosphere, and through the cloud/rain cycle. If you use UV light anywhere else in the process you will screw it up by creating a photoelectric current.
Donaldwfc:
--- Quote from: tutanka on October 23, 2011, 08:41:28 am ---
--- End quote ---
--- End quote ---
That doc is not related to Stan's work, you are confusing different systems. Read the exhaust gas reclaimer technology in the Tech Brief, it will tell you how to completely eliminate Nitrous Oxide.
[#] Next page
[*] Previous page
