Stanley Meyer > Stan Meyers system 2
Start here your topics on the resonance waterfuelcell with HHO injectors system
webmug:
--- Quote from: outlawstc on February 07, 2010, 17:28:08 pm ---thats what the steam resonantors job was.. to instantly heat water... it would keep the water from freezing in the fuel tank
--- End quote ---
Thanks, outlawstc
The 'Voltage Flexing Process' and the 'VIC Switchover Circuit' 8)
br,
webmug
TeslianH2:
I have a similar question re. Meyer's unit during freezing weather. Where I live we can get some serious weather conditions with temps dipping to sub-zero at times. With nothing running overnite how does he get the engine started from a non-running condition? The whole works would have frozen solid. Maybe he just keeps it running continuously in an idle mode.
Dankie:
Hes got that steam resonator thing getting switched on if the water passes a cartain treshold .
This is always on even when the car is shutoff .
A tiny pulses of energy every 20 minutes or so keeps the water warm for the next day .
Even I could do that if I had the steam resonator .
TeslianH2:
hmmmmmmmmmm, if you do the calculations required to keep h2o above freezing at 1 cal. per gram per degree C. you'll see that a goodly amount of energy needs to be sustained and expended. it's lot to ask of the battery if the engine is not running.
Dankie:
--- Quote from: TeslianH2 on February 07, 2010, 22:25:24 pm ---hmmmmmmmmmm, if you do the calculations required to keep h2o above freezing at 1 cal. per gram per degree C. you'll see that a goodly amount of energy needs to be sustained and expended. it's lot to ask of the battery if the engine is not running.
--- End quote ---
Thats because the Steam resonator is like a godly efficient heater and is on its own an OU like device .
Its works with "particle impact" as they say ...
[#] Next page
[*] Previous page
