Stanley Meyer > Stan Meyers system 2
Electronic unit
Steve:
Electronic unit
outlawstc:
these are pages from a international patent of stans from 1992
page one shows the basic layout of the control and driver circuit for a hydrogen gas fuel producing cell..
the way i see it is no one will see results until they achieve a circuit such as this one..
what is the variance and speed of change to the dielectric properties of water during the process???
as well as how precise does one need to stay tuned to this never ending variance to achieve increase in production?
FIGURE 1
is a block diagram of an overall control circuit showing the inter relationship of sub- circuits the pulsing core and resonant cavity.
(http://i82.photobucket.com/albums/j243/outlawstc/pic1.jpg)
FIGURE 2
shows a type of digital control means.. the type is determind by the goal.. for example a control means could be for sencing the need for acceleration in a automobile or a control means for controlling a home heating unit..
(http://i82.photobucket.com/albums/j243/outlawstc/pic2.jpg)
FIGURE 3
shows a analog voltage generator
(http://i82.photobucket.com/albums/j243/outlawstc/pic3.jpg)
FIGURE 4
is a voltage amplitude control circuit interconnected with the voltage generator and one side of the primary coil of the pulsing core.
(http://i82.photobucket.com/albums/j243/outlawstc/pic4.jpg)
FIGURE 5
is the cell driver circuit that is connected with the opposite side of the primary coil of the pulsing core.
(http://i82.photobucket.com/albums/j243/outlawstc/pic5.jpg)
FIGURE 6,7,8,9
relate to pulsing control means including
FIGURE 6
gated pulse frequency generator.
(http://i82.photobucket.com/albums/j243/outlawstc/pic6.jpg)
FIGURE 7
a phase lock circuit
(http://i82.photobucket.com/albums/j243/outlawstc/pic7.jpg)
FIGURE 8
resonant scanning circuit
(http://i82.photobucket.com/albums/j243/outlawstc/pic8.jpg)
FIGURE 9
pulse indicator circuit
(http://i82.photobucket.com/albums/j243/outlawstc/pic9.jpg)
FIGURE 10
shows the voltage intensifier circuit
(http://i82.photobucket.com/albums/j243/outlawstc/pic10.jpg)
FIGURE 11
is the gas feedback control circuit
(http://i82.photobucket.com/albums/j243/outlawstc/pic11.jpg)
FIGURE 12
adjustable frequency generator circuit.
(http://i82.photobucket.com/albums/j243/outlawstc/pic12.jpg)
Dankie:
Why dont you go ahead and do it and make the PLL or any pulser you may find more easy , learn ltspice and read about the PLL circuit . Many have made it work .
You dont "HAVE TO" make a circuit such as this one to test out Stan's main ideas .
outlawstc:
Donald
check out figure 5 .. this is Stans methods of driving the primary coil gate.. this circuit is connected to the opposite end of primary (negative/ south) notice theres a blocking diode there and there is a diode bridging north and south in opposite direction of the one gating to ground
now check out figure 4 this one is the one that the primary's north side connects to.. Stan has it where he can switch the positive side of primary to either a strait connection to positive on the battery or this a variable amplitude control means. this means during pulsing amplitude of positives source can variate causing the oscillation of amplitude of primary's positives connection while controls grounds interaction though figure 5 cell drivers negative connection
i wounder if tony being a electrical engineer could maybe throw some values in for the components and see if we can replicate this circuit.. it cant be to hard
TonyWoodside:
A1 and A2 in the Digital Control circuit looks like they could be Multiplexer chips.
[#] Next page
