Projects by members > Tony Woodside
Circuits I've built based on Stan's 8XA patent
(1/2) > >>
TonyWoodside:
(http://www.globalkast.com/images/tonywoodside/Digital_PWM-7.jpg)
This is the Pulsing Circuit fully adjustable from 1Hz - 10kHz. The duty cycle from the 555 chip is 95% and is then inverted by the 7404 to 5% duty cycle. All pulses from 7490 chips are 50% duty cycle.
(http://www.globalkast.com/images/tonywoodside/+5v_+12v_PowerSupply-5.jpg)
This is the Power Supply that provides +5v and +12v to the pulsing circuit. I have this power supply limited to 1A. I'm only using the +5v.
mina:
--- Quote from: TonyWoodside on July 01, 2010, 01:22:05 am ---(http://www.globalkast.com/images/tonywoodside/Digital_PWM-7.jpg)
--- End quote ---
The only problem is, the circuits do not show up in your posting as both of them never appear when the page with your post loads.
Regards,
mina
Steve:
It looks like that the website on which the pics are placed is not available.....
TonyWoodside:
Ok I have them back up and going now, my server was down. Thanks for letting me know guys.
-Tony Woodside-
charlieb000:
--- Quote from: TonyWoodside on July 01, 2010, 01:22:05 am ---This is the Pulsing Circuit fully adjustable from 1Hz - 10kHz. The duty cycle from the 555 chip is 95% and is then inverted by the 7404 to 5% duty cycle. All pulses from 7490 chips are 50% duty cycle.
--- End quote ---
hey tony,
i cannot find the 8XA circuit online! are you able to post it?
that circuit might exist in a scarce version of MEMO 420 (might be called MEMO 420 DA) that is called 'RE: Electrical Polarization Process' which i cannot find also (the well known 420 is about the 'fracturing process')... so thanks in advance for posting...
Charlie.
[#] Next page
