Stanley Meyer => Stanley Meyer => Thermal Injection => Topic started by: hydro on December 26, 2007, 14:26:50 pm
well pretty simple now that i used my Dremel to cuter open, it was well worth the wast!!! the picture says it all!!!
the magnetic coil is not wired to the barrel, so if i was to put this injector back together it would work if i hadn't destroyed it LOL.
now, you see the shinny spot on the casing? there are 2 of these, they're Electro Magnets.
in the end of the Factory injector, you would have seen 4 holes, about the size of half of a small sewing needle.
get rid of these 4 holes! im working on how.
you can see the ball point is the side that points to the motor, it does NOT have a hole in the end of hit, gas flows from the sides when the ball is pushed back by the electro magnet, this injector can pull .90 amps when hooked to a car battery. i would assume to use .50 amps.
the end hole i have showed with the 4 holes in where the gas comes out should have been drilled to one big hole.
now that i know and am sure how this works, i will take a new injector and drill me a bigger hole in it, with fear of lodging or sticking the injector.
i think you shouldn't drill the injector out, still not sure. things has changed now that water mist has came to play.
What's this injector out of?
1996 dodge neon
And that injector can flow gases?
it normally squirts gas out like a water pistil in 4 streams, it works good for a valve also, when the fluid starts to run out it will start to mist.
thats not gonna work , stan talks about the injector in the patents
