General => General Discussion => Topic started by: Logic on October 16, 2009, 02:42:30 am
This is just an idea that perhaps someone will test.
(Is ther a better place to post this?)
Dissolve exhaust gas in water and see how it does as an electrolyte:
CO2 + H2O ? H2CO3 (Carbonic acid) + dissolved CO2 (This is a weak acid)
C + H2O = CO (burns) + H2
Dissolved O2 (O2 will displace air: a good thing)
Thats about it; if you have a 3 way cat.
Without you also get:
NOx + H2O = 4 HNO3 (nitric acid) via a long process that includes HNO2, HNO3 and NO
CO + H2O = HCOOH (formic acid) + dissolved CO (This is a weak acid)
Unburned HCs + H2O = ??? (Didnt someone test a mixture of fuel and water in a cell and get good results?)
You will also get a small bit of hydrogen sulfide which dissolves in water to make a solution that is weakly acidic.
Perhaps this devil's brew is by some fluke the ideal electrolyte and gives great gass production and cleans up our exhaust a little! :D
What exactly the gas will consist of is a damn good question! :)
Certainly H2 and O2.
Perhaps CO (burns)
Possibly Nitrogen. :(
You may end up with carbon on the electrodes, which may or may not be good.
The gass hopefully will contain CO. (burns)
A simple test by bubbling exhaust through a bucket of water and using it in a cell would be interesting.
No idea how fast the solutes will be used up or how much of each will be in solution. ???
So what do you think??
http://mattson.creighton.edu/H2S/H2S_Info.html (http://mattson.creighton.edu/H2S/H2S_Info.html)
http://wiki.answers.com/Q/Is_carbon_monoxide_a_acid_or_alkaline_solution (http://wiki.answers.com/Q/Is_carbon_monoxide_a_acid_or_alkaline_solution)
http://en.wikipedia.org/wiki/Carbon_monoxide#Atmospheric_presence (http://en.wikipedia.org/wiki/Carbon_monoxide#Atmospheric_presence)
http://en.wikipedia.org/wiki/Nitrogen_oxide (http://en.wikipedia.org/wiki/Nitrogen_oxide)
http://en.wikipedia.org/wiki/Carbonic_acid (http://en.wikipedia.org/wiki/Carbonic_acid)
http://www.lanl.gov/news/newsbulletin/pdf/Green_Freedom_Overview.pdf (http://www.lanl.gov/news/newsbulletin/pdf/Green_Freedom_Overview.pdf)
Lets run on ammonia.
.... Ke? ??? (ala: Faulty Towers)
Nitrogen and hydrogen = ammonia
http://www.ecospec.com/index.html (http://www.ecospec.com/index.html)
Question:
Has anyone bothered to test the gas coming out the electrolyser?
Why are they not feeding it to the engine?
logic
nice one
try it please... ;D
thanks
