Projects by members > Dankie
Impedance matchings
(1/2) > >>
Dankie:
In here I will discuss impedance matching .
Everybody should learn this from allaboutcircuits.com , anybody is able to learn this ,
Its time to learn these things and to use them , those that stay ignorant and refuse to evolve their way of thinking should find a new hobby .
Steve:
--- Quote from: Dankie on August 20, 2009, 17:38:25 pm ---In here I will discuss impedance matching .
--- End quote ---
Ok, Dankie.
So what is the impedance we are looking for?
Dankie:
--- Quote from: Steve on August 21, 2009, 20:38:57 pm ---
--- End quote ---
Ok, Dankie.
--- End quote ---
First of all , nothing , just learn the basic math and prepare .
This is like the simplest  thing , you need to know the circle thing with angular speed and trigonometrie with triangles .
I still did not learn this at school , I will this year tho . But I did learn from all about circuits .
Those that have problems understandg the impedance and reactive stuff come here and ask your questipn . I have difficulty at first but once u get gooin you oly get better
You should make a math section Stevie ,so the ppl that have difficulty can ask questions .
Also , the Euler number needs to be covered and the Tau constant .
Dankie:
It has become clear to me that there is some algebra involved here , and the tubes ARE mechanically vibrating , theres our first parameter .
There is 2 parameters here that must be matched from these sentences .
 I just love how its all spelled out very clearly .
Dankie:
http://waterfuelcell.org/phpBB2/viewtopic.php?t=1309
 I will investigate what is known as''sound'' with some new modern equipment on the low budget tho, since there is alternating Q charge from those triplen tubes from inner to outer , the middle tube is in the best condition possible to start oscillating .
If it oscillates , it will create changing ''water pressure'' aka ''sound'' .  This will also correspond to maximum ''physical movement'' . There is also mention of how hitting the cell in the puharich papers can make the process run good again , this may be revealing .
Because thats what music is really , an digital recording of voltage levels being converterd to move a magnet that moves the cone up and down , wich changes air pressure and your ear piking those up as sound for your brain to decipher , it works in air just like it works in water .
I wont be ''trying my luck'' with stuff that is ''unworking''  , nothing can be copied , it must be understood first then matched , with 'efficiency' , not some 1000 watt powerhog just to excite a resonance .
[#] Next page
