Projects by members > Radiant_1
Atomic Hydrogen
(1/12) > >>
Radiant_1:
I believe that the "Atomic Hydrogen" reaction is one of great importance. It is most likely the key behind Meyer's Water Fuel Cell.
Basically if  we impart enough energy into molecular H2 (The kind we get out of Electrolysis Cells) it will separate into "atomic" or single atoms of Hydrogen..H1
Anytime an Atom changes phases there is a release of energy. In refrigeration the expanding or evaporation of liquid coolant to gaseous coolant creates an intense cooling. In the case of Atomic Hydrogen the arc's plasma core supplies heat energy which expands H2 to single atoms of Hydrogen...they are HUGE compared to molecular hydrogen (Much like liquid to gas ratios are huge)...when the single atoms of Hydrogen...hit something, subjected to certain catalysts, or other means are used to "bump down" the energy absorbed from the arc...A phase change will occur from H1 down to H2 (H2 is much physically smaller then H1)...the shrinking releases a LARGE amount of energy.
I believe this is what Meyer was working with...and in fact is the phenomena he called "Atomic Decay of Hydrogen"
Here is a theoretical use for this process...and a view of the life cycle
(http://i175.photobucket.com/albums/w152/Jdub6d9/Untitled-6-1.jpg)
Radiant_1:
Here's a couple patents that all use "Atomic Hydrogen" to release HUGE energy gains!!
In fact...the last one shows us that the process can be done to MOST NOBLE GASSES too! Hydrogen releases the most energy though...Helium is the second most energetic.
Radiant_1:
Here's a good one to try and wrap ur mind around
Steve:
Thanks radiant.,
Nice docs and theory's!
Alan:
http://jlnlabs.online.fr/mahg/index.htm
[#] Next page
