Projects by members > Bubz
Steam Resonator
Steve:
--- Quote from: Alan on December 16, 2010, 14:21:29 pm ---No details yet, haven't started yet. :) I chose to start with this because I think it proves work by voltage best.
Have you made one, Steve?
--- End quote ---
I used 2 tubes of 3 inch, like Stan said for many tests.
One test was with AC.
Similar to the tubes i send you...
Bubz:
OK Steve, I will give that a shot. I already have a few 3 inch cells as described in the documents, so this should be easy. What voltage levels do you suggest? Did you use an inverter?
Steve:
--- Quote from: Bubz on December 17, 2010, 01:31:52 am ---OK Steve, I will give that a shot. I already have a few 3 inch cells as described in the documents, so this should be easy. What voltage levels do you suggest? Did you use an inverter?
--- End quote ---
I simply hooked it up to my variac, Bubz.
Dont drop the tubes in a very large bucket, but use a drinkglas, orso....
Have fun!
Steve:
btw, use a smal gap between the tubes...
The smaller, the better results!
I ll gues that if you have higher frequency AC, you will see maybe better results...converter?
Dave:
I tryed the same thing a few months back, I burned up the wire leads when I turned the variac up to high. Steve is right I think, if we had higher frequency ac we could restrict amp flow just like the vic and prouduce hight voltage ac fields acriss the water without frying stuff.
have you made any progress?
[*] Previous page
