Projects by members > Steve
Plate cell by stevie1001
(1/10) > >>
Steve:
30cm by 10cm 304 plates   (11.8 inch by 4 inch)
1cm widt gasket for 3 quarters around each plate
0,5mm gap between plates 0.022inch!
hole of 3mm diam. (15mm of bottum) for waterlevelling
2,5V across each plate  5v between each + and -
+n-n+n-n+n-n+ etc
more to follow
Browngass:
That is about the size I was using in the first cell, do NOT align the water leveling holes, this prevent current leak between the plates
I aligned my holes to pump the cell, but I think it would perform much better if I haven't aligned them
It's better if you don't do the same mistakes that I did  ;D
Good luck on the build m8
Mr Brown/H2inICE
Steve:
--- Quote from: Browngass on July 21, 2008, 16:01:27 pm ---That is about the size I was using in the first cell, do NOT align the water leveling holes, this prevent current leak between the plates
Mr Brown/H2inICE
--- End quote ---
Thanks!
I learned from Kumaran some months ago about the waterlevel holes the same thing as you mentiond.
Did you say, you used a pump?
What was your gap between the plates? :D
Steve:
I orderd 50 plates today to start with
Hope to get them tomorrow! ;)
I got plexible pvc sheet for making gaskets today.
See what it will bring.
I just wondering what kind of housing to use.
Maybe i ll go for pvc tube (grey type for plumming) again....back where it all started with!
My first wfc with tubes was in such a housing...
This tube should be horizontal in my new setup. I may need more the 1 to fit it all in. Should be a cheap solution.
Or maybe i ll go for the famous flexiglas fischbucket.....LOL
Hmmmmm
steve :)
dudleyengineering:
what are you making a sealed cell or a submerged cell
[#] Next page
