Author Topic: My Herman Anderson replication project  (Read 36810 times)
« Reply #56 on: January 03, 2017, 15:24:12 pm »
How to measure 70kv with a spark gap distance:
0.5 cm: 17.0/17.0
1.0 cm: 31.3/31.3
1.5 cm: 44.5/44.8
2.0 cm: 57.0/57.4
2.5 cm: 68.8/69.3
3.0 cm: 78.8/79.4
3.5 cm: 86.6/88.0
4.0 cm: 93.6/....
4.5 cm: 99.8/....
5.0 cm: 105.5/....
From A.I.E.E Standards June 1940 as tabled in "Gaseous Conductors", J.D. Cobine, 1958. These are close to the values given in IEEE Std 4-1995 "IEEE Standard Techniques for High-Voltage Testing".
« Reply #57 on: January 05, 2017, 16:49:24 pm »
Update:
I brought my electrodes to the company that will plate them with Nickel.
Should get them back next week friday   :) :) :) :)
I am also getting 70kV out of my coils, already, which is also good progres!
cheers
« Reply #58 on: January 06, 2017, 10:33:19 am »
It would be nice if you could re start your Anderson project.
Sofar it is just you and me doing this.
Do you have maybe a suggestion for that oversized SCR ?
« Reply #59 on: January 06, 2017, 12:31:31 pm »
Ill gues i just will use a solid state relais for switching of the power to the positive of the cell.....
I found a nice one 1-100vdc and 80 amps SSR. I used them before and they do a good job.
cheers
« Reply #60 on: January 06, 2017, 23:24:38 pm »
Kevin, i am happy that we both take different routes. Lets see what works.
In the mean while, i am looking for the propane system of Anderson.
This is what i have sofar:
He used a secondairy regulator model J&S Carb Model 600.
A possible replacement: CLARK 721019 REGULATOR
However, i cannot find sofar the specifications of that replacement part.
http://www.ebay.de/itm/CLARK-721019-J-S-MODEL-600-SECONDARY-REGULATOR-NEW-REPLACEMENT-LPG-IMPCO-JS-GAS-/181115563574?_trksid=p2141725.m3641.l6368
250 euro's!!!
Alternative? : https://carbturbo.com/product/impco-beam-t52n-n-2/
« Last Edit: January 07, 2017, 00:01:26 am by Steve »
« Reply #61 on: January 07, 2017, 16:15:30 pm »
The other component of the hydrogen installation is the IMPCO 300 mixer carburator...
« Reply #62 on: January 07, 2017, 16:32:03 pm »
The engine was a Ford 351 CID V8.
Something like this one:
« Reply #63 on: January 07, 2017, 16:49:57 pm »
and a new hydrogen flow meter arrived from Hongkong  :)
« Last Edit: January 07, 2017, 21:22:50 pm by Steve »
