Author Topic: Finaly getting results  (Read 18830 times)
Re: Finaly getting results
« Reply #24 on: February 20, 2010, 23:19:09 pm »
if you go to "resonant action" where particle impact is brought on by charged particles subject to voltage attenuation, the gasses will be jet propelled out of the resonant cavity and out of the water... would solve that problem...
« Reply #25 on: February 21, 2010, 01:22:48 am »
You know Don your probably right.
Still working on that part.
If I saw it I probably would not know anyway because I don't know what it is. (Yet).
Maybe one day we'll stumble on to it.
Got to keep picking away at all those variables, and keep reading.
Meanwhile I'm working on what I can with this tube set to keep pushing hopefully in a positive direction.
These tubes may have to be more tuned in. Meaning the individual capacitance of each tube set when built should have been matched. The weight of each tube could be matched so each is the same mass in each set.
Many things could have been better prepared.
Now I should match each with its own coil to try to fix my mistakes which I think is possible.
If done properly from the start this may have been a lot easier.
« Reply #26 on: February 21, 2010, 01:40:39 am »
Hi JohnD,
Hows it coming along?
Have you taken any more measurements of your system.
I know you said you had 1.5a on rotor.
But also can you take a current reading of the secondary side?
How many diodes are you using 3 or 6?
Lots of questions!
« Reply #27 on: February 21, 2010, 13:14:29 pm »
Hi JohnD,
Lots of questions!
Hello Komtek , ive just done some more tests . On full tilt this time it peaked at about 1.8 amps going into the rotor and about 4.5 amps out . I said before that i was getting about 100v out but that was with distilled water . Im using spring water now and the volts out  has droped to 25 v .
Here's the scope on the output with no pulse :
http://www.flickr.com/photos/45482143@N08/4375712552/
And here's what looks like the step charging effect with the rotor pulsed :
http://www.flickr.com/photos/45482143@N08/4374964543/in/photostream/
Ive done another video clip thats a bit clearer too :
John
« Reply #28 on: February 21, 2010, 13:18:34 pm »
Oh yeah ....... and using a 3 phase bridge rectifyer .
« Reply #29 on: February 21, 2010, 17:59:08 pm »
John, I just love the Lawton type enclosure how it blends together.
I'm interested in the fine details of the complete build.
You have done a exceptional replication job.
Saw those chokes you put inside the alternator is that a standard 100 turn wind and on what core and material wire size?
Do you mind with details?
Can we email or PM?
« Reply #30 on: February 21, 2010, 19:30:57 pm »
Chokes? I didn't see any chokes. Do you still get the step charge effect without the chokes? Great stuff!
« Reply #31 on: February 21, 2010, 20:38:17 pm »
Yes looking through the site where JohnD posted he has several pictures.
You see the chokes. Great idea JohnD!
