Projects by members => Projects by members => Dankie => Topic started by: Dankie on January 16, 2009, 00:57:16 am
Title: Impurities extractor
Post by: Login to see usernames on January 16, 2009, 00:57:16 am
http://www.ionizationx.com/index.php/topic,836.0.html
In this thread I talk about the impurities extractor , I will be working on this before I do anything with the VIC. I still need more tools for my VIC but I will investigate this impurities extractor while I wait for extra tools .
From the looks of the picture this looks small , I'm gonna try a few things .
Now everybody thats stuck with a cell should do like me and experiment with this  design .
Title: Re: Impurities extractor
Post by: Login to see usernames on January 16, 2009, 12:08:48 pm
Thats a good topic to start.
Stan had something in his system with an electrode.
Lets find out what he did with that.
Post by: Login to see usernames on January 18, 2009, 03:15:43 am
Great video here , I have a great design in my mind that could trap particles really well .
Post by: Login to see usernames on January 18, 2009, 04:33:24 am
http://www.ndt-ed.org/EducationResources/CommunityCollege/MagParticle/Physics/CoilField.htm
This is what I think is happening , since we know Stan likes to put coils where you think they are none . Here is my modification/interpretation based on my understanding looking at pictures of magnetic field , yes I know its pathetic I am no engineer  . So we know this acts as a pump correct ? we know also that the B field will never be strong enough to work as a pump on its own  , so we must use the field from the wire itself  . The 2 upper large sections are semi-flat coils , they trap the particle inside . The central beam (core) is stainless steel and between each coil there is strong magnetic field and particules follow that field like the rule of thumbs and videos , they latch onto the stainless steel core and turn around it like in the video . There is a thick plastic seperation between each post .
All this is pulsed by high voltage , there might be a wall that traps the molecules and doesnt let them turn constanly and never come back into the system agaian unless the power is cut and water shaken again ...
The + and - signs are the polarity of each individual post
Post by: Login to see usernames on January 18, 2009, 04:37:51 am
I need comments plz  , suggestions , observations .
Plz communicate your ideas  well and make a sketch if you have to.
I have most of the tools for this , will try some different stuff  and will test any ideas you guys will give me , I will make this with s/s wire since I have much of this .
I have other ideas in mind besides this one , I will frikkin try everyhting and observe .
This is my project for now .
Post by: Login to see usernames on January 18, 2009, 22:14:23 pm
Nice video, Dankie!
Not sure if it shows the right direction, but it is good food for thought!
Post by: Login to see usernames on January 18, 2009, 22:16:53 pm
Nice video, Dankie!
Not sure if it shows the right direction, but it is good food for thought!br
Yup it sure is good food for tought
Post by: Login to see usernames on January 18, 2009, 22:25:11 pm
Hi Dankie,
I still have to run some tests to find out what exactly the brown stuff is and is it has any magnetic of electric attraction.
Hope others will join in there.
Post by: Login to see usernames on January 18, 2009, 22:27:34 pm
Hi Dankie,
Yes it does , I will edit my picture above and show that the pump is meant to go with the cell , its also needed for the conversion kit .
Yes I believe this is key to have a nice healthy durable cell .
Post by: Login to see usernames on January 19, 2009, 01:21:24 am
I have just tought of a new conception .
I will call it the SUPER-MEGA inner outer vortex coupling infinite black hole of no escape of despair
Post by: Login to see usernames on January 19, 2009, 09:13:01 am
That name is too long.
How about: the dankie vortex ? ;)
Post by: Login to see usernames on January 20, 2009, 01:05:33 am
I believe I understand the concept now , this is very needed so you dont accumulate impurities in a big cell and its used for the injector to turn tap water into perfect distilled good dielectric . I believe 100% pure water can be attained by magnetic filtering .
I have another idea wich is different from this as both magnetic fields from the coils go inwards and the current passes throught the impurities from one coil to the other , this is indeed an excellent dual usage design . With enough voltage this thing will suck up anything remotly ionic and leave nothing but pure water .
Im gonna manoeuvre around the resonant locking and find the pattern for starters  . Control the temp old fashion way ... Ill have a much more stable PLL circuit if I stay within a tiny margin thats if I need one at all ...
This is within my grasp , I'll use stainless steel wire so I can make this small and less amp consuming . Ill probably go into the range of  2-3 KV input in a small enough compartment .
Title: Dankie vortex
Post by: Login to see usernames on January 20, 2009, 19:01:30 pm
Post by: Login to see usernames on January 20, 2009, 20:04:15 pm
Interesting theory, Dankie.
Do you find time to do some tests on this? Or are you bussy winding the VIC?
