Electrolysis => Fuel Cells => Plate Cells => Topic started by: Fiditti on May 14, 2008, 16:09:22 pm
Title: Joe Cell
Post by: Login to see usernames on May 14, 2008, 16:09:22 pm
I'd like to request a new category for the Joe Cell.  I've been having a certain degree of success with this cell.
Title: Re: Joe Cell
Post by: Login to see usernames on May 14, 2008, 19:57:49 pm
Very nice.
Can you put some pics of your Joe Cell here?
And are you gonna try to run an engine on it?
Br
Title: Re: Joe Cell
Post by: Login to see usernames on May 14, 2008, 20:03:06 pm
You may want to consider using a Experimental Life-Energy Field Meter to measure your Joe Cell:
http://www.orgonelab.org/cart/ylemeter.htm
The Experimental Life-Energy Field Meter meter works along entirely new principles quite different from any other measuring device currently on the market. Is entirely different from ordinary "EM-field" meters. It is not responsive to electromagnetic fields, nor to static magnetic or electrostatic fields. An electrostatically-charged plastic comb or wand, for example, will show no reactions to the Life Energy Field Meter, other than what would occur from the same plastic comb or wand without the electrostatic charge. This is quite different from the usual voltmeter, which reacts strongly to electrostatic fields. Likewise, no greater readings will be developed between an ordinary piece of metal, or the same piece of metal stronly magnetized. The Life Energy Field Meter responds only to the presence of living organisms, and also more weakly to liquid water, and to moisture-bearing and metal-containing materials which as Reich demonstrated, are strong absorbers and reflectors of atmospheric orgone energy. The Life Energy Field Meter will, for example, respond strongly to the field from a nearby orgone energy blanket, or orgone accumulator, with a general indication of the relative strength of charge -- however, much research is needed before we can be too declarative, beyond these general statements. Consequently we consider it an experimental device.
IndianaBoys
Title: Re: Joe Cell
Post by: Login to see usernames on May 15, 2008, 14:23:36 pm
 I'm not familiar with the size requirements here, but, usually, roughly, 450 pixels X 450 pixels, is a common size.
  Download xat.com. It's a free image optimizer, and very easy to use.
Title: Re: Joe Cell
Post by: Login to see usernames on May 15, 2008, 14:28:16 pm
How do I post pics here?  Thanks.
Yes, I do plan to run cars on the cell.  I have been told that once you start running cars on the cells that it's hazardous to talk about it.
Best Regards,
Fiditti
You have an option when you are making an reply: Additional Options
Click on that and you can add pics
When you run your car on a joe cell, you are a hero!
If you are scared, just PM me your results.....and i keep them in secret.
vr
Title: Re: Joe Cell
Post by: Login to see usernames on May 24, 2008, 20:34:14 pm
So, I opted to go back to the 3/16" cell.  I'll keep you posted if you like.
Best Regards,
Fiditti
Yes, please.
Title: Re: Joe Cell
Post by: Login to see usernames on May 24, 2008, 22:20:52 pm
Dear Fellow Members,
1/2" Gap Joe Cell Experiment:
Well, I tested my new 1/2" gapped Joe Cell today and was less than pleased with it.  I was so unhappy with it that I disassembled it this afternoon.
I have been using a cell with 3/16" gap.  It was very active cell.  You could feel the energy.  You could see something happening, (i.e.: the water was swirling about; a cold mist formed at the top of the cell; the cell was cold to the touch; there were small bubbles comming up to the surface; the cell looked alive).  The 1/2" gapped cell looked dead.  So, I opted to go back to the 3/16" cell.  I'll keep you posted if you like.
Best Regards,
Fiditti
Very nice!
Good pictures too!
Keep on posting!
Title: Re: Joe Cell
Post by: Login to see usernames on July 11, 2008, 00:22:29 am
I read on other people storys that they had the same bad feeling when the north and south of the tubes were mixed..
Its an interesting device!
Title: Re: Joe Cell
Post by: Login to see usernames on July 11, 2008, 02:42:16 am
Fiditti
I've heard the same thing also.
Something about messing up your bodies natural magnetic flow.  ???
But , Anyways, I've also read some very interesting bit on Joe cells,
 And I look forward to seeing future posts, And findings.
The way they operate is much different than I'm used to,
So I'm very interested in what you find.  :o
Spike
Title: Re: Joe Cell
Post by: Login to see usernames on August 20, 2019, 09:51:40 am
A new more fitting theory on the Joe cell!
Watch this video....
feature=youtu.be
