Stanley Meyer => Patents, documents and pictures of Stanley Meyer => Topic started by: Steve on January 30, 2011, 16:26:03 pm
Title: Patents and official documents of Stanley Meyer
Post by: Login to see usernames on January 30, 2011, 16:26:03 pm
Here are all Patents of Stanley Meyer and other official released documents.
Title: Re: Patents and official documents of Stanley Meyer
Post by: Login to see usernames on May 08, 2011, 19:01:02 pm
Thanks Steve, Re-reading once again...
Post by: Login to see usernames on May 08, 2011, 20:19:13 pm
LOL...i did too.....for the 1000th time....
I found again a piece that got my attention...
Post by: Login to see usernames on May 08, 2011, 23:00:20 pm
Me too! Its very suspicious the subtle changes in the text!
Release atomic energy under controlled state by applying electric fields. wow
Makes lot of sense for me, the physicists don't see this, they can only see a chain reaction neutrons and ever lasting radiation...
for me is clean
Post by: Login to see usernames on May 09, 2011, 00:09:30 am
This is what is keeping my mind tickeling. First Stans text. Then the text after deleting lots of crap talk:
First water mist (47) of Figure (4-4) is injected into fuel-mixing chamber (35) of Figure (45) by way of
water spray ports (41a xxx 41n) of Figure (4-4); Secondly, ionized air gases (46a xxx 46n) of Figure (4-
4) (laser primed ambient air gases having missing electrons) produced by Ambient Air Ionizer (80) of
Figure (4-6) as to Figure (4-1) and non-combustible gases (45) of Figure (4-4) are intermixed with
expelling water mist (47a xxx47n) to form Water-fuel mixture (48) by way of gas mixing disc (34) of
Figure (4-5) as to (30) of Figure (4-2); thirdly, the resultant moving Water-Fuel mixture (48) of Figure
(4-5) enters into Voltage Igniter Stage (180) of Figure (4-5) and exposed to hjgh intensity voltage fields
(33/36) (typically 2,000 volts or above @ 10 Khz or above) of opposite electrical polarity (E7 / E8) ...
which, in turn, not only performs electrical polarization process (160) of Figure (3-26) undergoing
Dielectric Resonant (240) of Figure (3-31); but, also, sets up and triggers Hydrogen Fracturing Process
(390) of Figure (3-42) as to Figure (3-6) under control state (on demand) via electrical-static spark
ignition (49/51) of Figure (4-5) .... releasing thermal explosive energy (gtnt) (16) passing beyond gas
exit port (32) of Figure (4-5), as further illustrated in Figure (4-2) as to Figure (4-1).
First water mist is injected into fuel-mixing chamber.
Secondly, use ionized air produced by Ambient Air Ionizer.
Third, add as option exhaust gasses = watervapour, if it runs on water
Fourth: use a plasma sparkplug system
Long story short. I must add a startermotor on my generator........then i can go run tests with ionizers, watermist and plasma sparks...
Post by: Login to see usernames on December 23, 2012, 18:01:53 pm
After all these years, i finally got some original manuals of Meyer....
I will scan these in januari and share them with you all... :)
Merry Christmas!!! HHOHHOHHOHHOHHO  ;D
Post by: Login to see usernames on December 23, 2012, 19:08:18 pm
Steve,you are the Great man!!!
Blessing
geenee
Post by: Login to see usernames on December 23, 2012, 23:30:06 pm
cant remember seeing this one
Post by: Login to see usernames on December 24, 2012, 12:59:33 pm
The manuals and documents of Stanley A Meyer, when posted at Ionizationx,  will not only preserve
the written legacy of  a truly remarkable person but also serve as a standard to compare with other
copies of  his work. New scans of the photographic images will have slightly different gammas which
bring out details not visible in previous scans. For serious experimenters, archivists and photogrammetric
enthusiasts,  this is a remarkable find that Steve at ionizationx is sharing with the HHO community.
Post by: Login to see usernames on December 24, 2012, 13:11:40 pm
You are welcome, Jim.
I have two versions of the sales manual and there are some differences. I looked them thru paga by page..
It is strange to have them here in my hands...
Also the info brochure number 6 and the tech manual are much better to read, somehow.
I will create some pdf's of them.
Post by: Login to see usernames on December 26, 2012, 20:54:06 pm
This is good work, Steve  :)
Cheers!!!
Br,
Webmug
Post by: Login to see usernames on March 26, 2017, 11:02:14 am
the dealer manual!
Post by: Login to see usernames on March 26, 2017, 12:11:16 pm
Nice work, thanks a lot Steve !
I have done a similar work this Stanley MEYER's patents (cleaned scanned documents and making an OCR of the text) in order to be able to make keywords searches on all documents. I will add this one in my dedicated search folder !
(I will make a new post to share my work too.)
http://www.ionizationx.com/index.php?topic=3183.msg30476#msg30476 (http://www.ionizationx.com/index.php?topic=3183.msg30476#msg30476)
Post by: Login to see usernames on October 11, 2018, 21:09:29 pm
Stanley Meyer Autopsy Report posted at ionizationx.com
