Alternative Energy => Low Cost Devices => Topic started by: Steve on April 25, 2010, 16:42:49 pm
Title: AC powerfactor correction to save money
Post by: Login to see usernames on April 25, 2010, 16:42:49 pm
Here the start of a off topic subject.
However, we all might save us lots of money, which we then can use for our waterfuel projects... ;D
feature=related
feature=fvw
In this video you hear the man talking about not being able to save money, but is he correct?
His amps drop. his volts drop, so in my opinion, his powermeter should drop as well.....
What are your thought on this?
http://en.wikipedia.org/wiki/Power_factor
http://www.allaboutcircuits.com/vol_2/chpt_11/3.html
Title: Re: AC powerfactor correction to save money
Post by: Login to see usernames on April 25, 2010, 16:50:48 pm
feature=related
An illigal one...hehehehehe
feature=related
Post by: Login to see usernames on April 25, 2010, 17:06:05 pm
I have been wondering about that my self, and planing to test it out.
here is my plan:
use my existing PF meter and check the power factor of an inductive load like a motor.
then turn off the power for the entire house. and power the motor only.
use a stop watch and check how long it takes for the electric meter to complete one turn.
then correct the power factor and check the electric meter again.
from what I read about PF, it can only be adjusted on inductive loads.
Post by: Login to see usernames on April 25, 2010, 17:26:17 pm
As far as i know you only pay for the real power at the plug anyway. the energy stored in inductive/capacitive elements isn't lost anyway and and recycled fully.
Post by: Login to see usernames on April 25, 2010, 22:36:53 pm
here is my plan:
Same here.
Just run some tests on it.
If my meter is slowing down when i corrected the powerfactor, then we have a point, is it.
Post by: Login to see usernames on April 25, 2010, 22:48:01 pm
Does anybody know the difference between the digital meters and the old "wheel" meters?
Post by: Login to see usernames on April 25, 2010, 23:17:08 pm
160uF cap to correct the power factor on your waschinemachine......
Post by: Login to see usernames on April 25, 2010, 23:19:59 pm
Hmmmm,
Maybe i have to correct the powerfactor on my variac.....
Then i will be sure come closer to having a closed selfsustaining generator on HHO.
Post by: Login to see usernames on April 26, 2010, 00:28:25 am
feature=channel
Post by: Login to see usernames on April 26, 2010, 11:44:01 am
In a purely resistive circuit, all circuit power is dissipated by the resistor(s). Voltage and current are in phase with each other.
In a purely reactive circuit, no circuit power is dissipated by the load(s). Rather, power is alternately absorbed from and returned to the AC source. Voltage and current are 90o out of phase with each other.
In a circuit consisting of resistance and reactance mixed, there will be more power dissipated by the load(s) than returned, but some power will definitely be dissipated and some will merely be absorbed and returned. Voltage and current in such a circuit will be out of phase by a value somewhere between 0o and 90o.
Post by: Login to see usernames on April 26, 2010, 11:51:19 am
This correction, of course, will not change the amount of true power consumed by the load, but it will result in a substantial reduction of apparent power, and of the total current drawn from the 240 Volt source.
http://www.ibiblio.org/kuphaldt/electricCircuits/AC/AC_11.html#02223.png
Post by: Login to see usernames on April 27, 2010, 16:36:48 pm
interesting stuff
Post by: Login to see usernames on April 27, 2010, 16:44:01 pm
another one
Post by: Login to see usernames on April 27, 2010, 16:49:06 pm
th
Post by: Login to see usernames on April 27, 2010, 16:54:02 pm
http://freecircuitdiagram.com/2009/07/05/active-power-factor-correction-circuit/
