Projects by members > Haithar
My new approach
Hydrocars:
--- Quote from: haithar on November 16, 2009, 23:04:09 pm ---i had some ideas while watching a parallel resonant circuit.
watch closely at 400 Hz.
(http://a.imagehost.org/0608/parani.gif)
now i wanted to see if it is possible that two lights glow intensely while the one is glowing very dim, indicating a minimum in power input into the circuit.
that is indeed possible if all bulbs are identical! the resistance of the whole circuit is in resonance R = 1.5 * Rbulb (it's a maximum),
which means it's larger than the one bulb alone but lighting three, two of them very intense. The current through cap and coil cancel each other out.
now let's see if there could be any use for a water fuel cell which needs current for electrolysis.
the important thing with a water capacitor is the leaking as an ohmic resistance which is measurable as current with dc voltage. this resistance has to be very large and coil and cap have to be tuned to ensure a high Q rating.
--- End quote ---
Nice Post @ Outlaw.
Also, Haithar The fuel cell is a load when connected, Meaning it is a resistor. It restricts amps. However, It is also a capacitor since it holds a brief low voltage charge. The fuel cell is much like a capacitor and resistor in parallel.
haithar:
i guess so, but in all equivalent circuit diagrams i've seen the dielectric losses are arranged as a resistor in series, only the losses over-time which lead to self-discharge are arranged parallel.
well there is no doubt that even at dc there is current flowing through the capacitor, that must be minimized in order to get a high Q rating.
i'll read your posts again sebosfato
sebosfato:
What did you think about? Did you understood that the complex impedance of a parallel resonant circuit at the frequency stanley stated could perfectly have about 40Megaohms of resistance thus use about 1ma for 40kv as i said?
Thanks for reading
this is your luck day, believe
haithar:
even if it was like that, stanley does not have a parallel resonant circuit but a series circuit.
how should there be any current "recirculating" (as you call it)?
or is the bifilar coil your parallel lc-circuit?
haithar:
sebosfato, can you elaborate about the parallel circuit in a stanley meyers setup?
[#] Next page
[*] Previous page
