Author Topic: Starting my project :Tube cell  (Read 1666 times)
Offline Hidden
Re: Starting my project :Tube cell
« Reply #30 on: August 15, 2009, 21:04:52 pm »
Stan's Demo Cell had a 0.090" Gap, which is 2.286 mm
In the Fuel Gas patent he says 0.0625", which is 1.5875 mm for a 4 inch cell
In the Circuit Patent he says 0.125", which is 3.175 mm for a 3 inch cell (the famous 5 gallons of water split per hour)
In the TB for the injectors he states from 0.060" to 0.010" which is 1.524 mm to 0.254 mm
The quenching circuit comes into effect at 0.025" to 0.015" which is 0.635 mm to 0.381 mm, or smaller
I wont show you any math just to keep things simple.
Suggestion for buying tubes: Stan uses thin wall tubes for the demo cell, outer was .750" OD, 0.035" thick, inner was 0.500" OD 0.049" thick, these are standard sizes you can buy, yes it was a typo in the drawing, he simply left out a zero, and for the inner and outer tubes, they weigh about exactly the same. Also, thin wall tubes are cheaper, and more likely to vibrate in the audio range.
Offline Hidden
« Reply #31 on: September 07, 2009, 19:50:21 pm »
Hi Donald,
Thanks for your reply sir.
What you say, makes sense.. but i have no experience with that mysterious viberations within the tubes i have seen been discussed here...
Another reason why thin tubes is the best alternative when building a big cell for keeping the weight lowest possible.
I have seen SS 304 (A2) is getting a bit rusty after long use, so i would replace with 316 (A4) quality instead.
You may collect rainwater in a plastic barrel for testing with low mineral content for lower amp draw.
I bet the gap is important, but we can finetune the resonance with the VIC so it matches any gap...when we got it fully working i guess..  :)
« Last Edit: September 07, 2009, 20:19:36 pm by WaytoGo »
