Author Topic: Impurities extractor  (Read 769 times)
Offline Hidden
Re: Impurities extractor
« Reply #10 on: January 19, 2009, 09:13:01 am »
That name is too long.
How about: the dankie vortex ? ;)
steve
Offline Hidden
« Reply #11 on: January 20, 2009, 01:05:33 am »
I believe I understand the concept now , this is very needed so you dont accumulate impurities in a big cell and its used for the injector to turn tap water into perfect distilled good dielectric . I believe 100% pure water can be attained by magnetic filtering .
I have another idea wich is different from this as both magnetic fields from the coils go inwards and the current passes throught the impurities from one coil to the other , this is indeed an excellent dual usage design . With enough voltage this thing will suck up anything remotly ionic and leave nothing but pure water .
Im gonna manoeuvre around the resonant locking and find the pattern for starters  . Control the temp old fashion way ... Ill have a much more stable PLL circuit if I stay within a tiny margin thats if I need one at all ...
This is within my grasp , I'll use stainless steel wire so I can make this small and less amp consuming . Ill probably go into the range of  2-3 KV input in a small enough compartment .
Offline Hidden
Dankie vortex
« Reply #12 on: January 20, 2009, 19:01:30 pm »
« Last Edit: January 22, 2009, 04:49:30 am by Dankie »
Offline Hidden
« Reply #13 on: January 20, 2009, 20:04:15 pm »
Interesting theory, Dankie.
Do you find time to do some tests on this? Or are you bussy winding the VIC?
