Author Topic: !!!STAN MEYER EPG ELECTRICAL GENERATOR ...CRACKED.....!!!  (Read 11616 times)
Offline Hidden
« on: October 30, 2008, 17:43:53 pm »
STAN EPG ELECTRICAL GENERATOR
HOW CAN WE MAKE IT?????????
Offline Hidden
Re: !!!STAN MEYER EPG ELECTRICAL GENERATOR ...CRACKED.....!!!
« Reply #1 on: October 30, 2008, 17:49:23 pm »
Yeah all those who expect to power something using an electrolyser , w/e electrolysing method either regular or special step charging method need to build this first.
All their efforts will be in vain without this hahahaha..... you cant power shit with an electrolyser.
Online Hidden
« Reply #2 on: October 30, 2008, 18:32:03 pm »
its possible that meyer made the gas from his wfc magnetic going into the epg.
After that he mayby added lasers and hv and up into the engine. I do not know any researcher making an epg like stan.
I can confirm that it is possible to light a bulp on a wfc in the pulse down time.
I also confirm that it is possble to power a small fan with 2 electrodes in the gasflow of the wfc.
Offline Hidden
« Reply #3 on: October 30, 2008, 22:43:40 pm »
yeah with an electrolyser you need free energy from the the epg , or some very extensive laser primer + electron extraction  to make the gas more powerful .
Its clear that nobody here has enough knowledge to accomplish either .
Online Hidden
« Reply #4 on: February 18, 2011, 13:56:17 pm »
Maybe this is what Meyer was doing with the EPG.
He changed the para state of hydrogen into the ortho with help of electromagnets.
But at the same time that the gas becomes magnetic, he also collects electricity from it by circulating the gas thru coils at the same time?
Hmmm EPG and EEC...
Here the patent on changing para into ortho using magnets. This patent is the reason why Simon Ruskin utility patent was taken down.
They where the same.
This technique is used to energize your petrol . Just put ring magnets like the drawing is showing
around your fuelline and bingo!
Offline Hidden
« Reply #5 on: February 18, 2011, 15:28:00 pm »
Yes that is because whenever anything moves thru crossing electro or magnetic fields the result is electromagnetic energy right into the molecules... this makes the gasoline to break into smaller molecules (atomize) thus they burn more fully.
Regarding the EPG I guess its only about being able to ionize the water for generating already destabilized gases ionized so they interact really strong with the magnet therefor getting magnetized like stan said.
The secret is that the gas might have a net electric charge. I think that for the epg a plastic tube with the coils would be feasible.
Do you remember that test (explosion) =)
I think you just need to charge water to high voltage to accomplish this. The thing is that is not only the gas passing thru the tube that generate electricity. We need to 1° create a closed loop, 2° the epg might work like a transformer to amplify energy. I think he use the same principle of kapanadaze or don L smith cause they were doing something like this but simpler. They just charged the resonating coil negatively so free electrons (unbounded) extra electrons get to move thru the coils freely amplifying the magnetic flux. (because of the same principle if you pass a charged particle thru a coil it generate electricity).
Stan electrical gas generator patent is what i'm talking about cause i'm referring to oxygen and hydrogen and not the EPG where he uses a special gas and lazer to accelerate and keep the particles ionized.
Offline Hidden
« Reply #6 on: February 21, 2011, 05:29:50 am »
To comment on this idea,
As science works on principals why not try this on a small scale?
Stan you have a cell hooked up to an engine already correct?
Do you have the resources/time/want to test this theory?
As you already have the setup, placing a metal (copper perhaps) tube as a section of pipe that the HHO needs to transverse through to get to your engine. Once you have a stable production/engine speed (the lower the better), apply voltage increase (in both potentials) to the tube. If the theory has benifits (voltage of a particular charge can increase the "power" output of the gas) your engine speed should increase. This would become apparent by the simple sound of the engine running. If your get to say 5kv(??) and there isn't even the slightest change then your can put the idea of HV exposure to rest. If it does work then you only need to incorporate this efficiently.
Offline Hidden
« Reply #7 on: February 18, 2014, 15:21:05 pm »
Im working on it. Breakzeitgeist@gmail.com look up  on youtube
