Author Topic: My tube cell, i need your ideas & suggestions  (Read 1410 times)
Offline Hidden
Re: My tube cell, i need your ideas & suggestions
« Reply #20 on: September 29, 2008, 15:34:55 pm »
it's not, because of one of your posts, i just looked through the documents again and compared it to my setup.
the only thing which is not accurate are the tubes, the gap is much much smaller and the coating isn't as good, but i cannot see how an isolating coating could increase the production.
Offline Hidden
« Reply #21 on: September 29, 2008, 16:04:51 pm »
i'll keep on conditioning until the weekend and then i'll measure it with an easy way.
cant stop without knowing my efficiency ;)
hope you know what i mean with the picture, everythings underwater, the gas goes into the measuring pitcher and is collected at the top.
Offline Hidden
« Reply #22 on: October 07, 2008, 17:09:22 pm »
I tested output, disappointin ;) some cc per minute, not very much, even compared to the 2.3Wh/l.
Damn..
Btw, this is why you do not want to use a gap which is too small. tubes cannot be cleaned of the brown muck, water cannot flow through it as it should, resistance is too low (therefore current is too high)
MOV00048.3gp (474 KB)
« Last Edit: October 07, 2008, 22:47:23 pm by haithar »
Offline Hidden
« Reply #23 on: April 13, 2009, 09:47:00 am »
I suggest you insulate your cell walls with dielectric spray, typically 70 kV can be reached. Then measure inductance at different freqs with a digital LCR meter. The LCR meter is EXTREMELY important for success, in fact without it nothing will be controlled. With this instrument you will learn how to control L, C and R values with different spacings, insulations and at different freqs.
