Author Topic: Tesla Switch as Electrolysis Circuit  (Read 1718 times)
Offline Hidden
  • Yes I got Jolted,
Re: Tesla Switch as Electrolysis Circuit
« Reply #10 on: March 31, 2010, 16:59:48 pm »
I should have posted my test results back when I tested.
the circuit is an illusion, it makes you thing that the energy will be flowing from the higher voltage side to the low side.
if using 4 12 volt batteries then one would think that the the 2 batteries in series (24 volts) will charge the 2 batteries in parallel (12 volts) and this is in did true, but the total energy available in the 4 batteries will last the same time if wiring all 4 batteries in parallel to power a 12 volt circuit.
for example if you have a load that uses one amp at 12 volts.
when powering such load from this circuit, it will be drawing 1 AMP from the 24 volt batteries so 24 x 1 = 24 watts. and it will be charging the 2 batteries in parallel at 12 volts at one AMP = 12 watts.
so the 24 battery pack is draining at a rate of 24 watts
the 12 volt battery pack charging at a rate of 12 watts
and the load is using the other 12 watts.
Offline Hidden
  • Energy4All
    • Energy4All
« Reply #11 on: March 31, 2010, 18:52:26 pm »
Hello Electrojolt. You may want to look at the solid state designs EnergenX Inc. are using. The relays will introduce a delayed response; but the coils in them may be put to use as a radiant energy sequestration device. Up sides and down sides to the coil relay I guess.
