Author Topic: Complete beginner queston......  (Read 483 times)
Offline Hidden
Re: Complete beginner queston......
« Reply #10 on: January 30, 2012, 17:25:06 pm »
did you call his house or his office
 i believe it was his home because his wife answered the first time saying to call back after 6pm
Offline Hidden
« Reply #11 on: January 30, 2012, 19:17:45 pm »
ok this is my theory on the purpose of the Gate pulse. When you have the depletion layer form on both electrodes, it will get larger and larger as the  voltage increases. At some point the voltage will make the depletion layer large enough that the two will meet and cause a bridge between the two electrodes. This will cause a dead short condition and current will flow and voltage will drop and you will have a loss of resonance. So this is where the gate comes into play, it limits the depletion layer from getting too big and causing the bridge between the two electrodes.
The B+ & B- depletion layers causes a pulling force on the molecule and  the stripping of the electrons and when the gates switch off, the atoms will link back up as diatomic hydrogen.
Offline Hidden
« Reply #12 on: January 30, 2012, 21:49:08 pm »
THE ELECTRICITY MAP: "Static" Electricity versus "Current" Electricity
http://amasci.com/miscon/ele-map.html
Look left bottom in figure CURRENT vs VOLTAGE: "molecular bondings (<<100nA and <<10V)"
The Electrostatic Charge of a Capacitor
http://www.wisc-online.com/objects/ViewObject.aspx?ID=ACE11805
"STATIC ELECTRICITY" MISCONCEPTIONS
http://amasci.com/emotor/stmiscon.html
"CAPACITOR COMPLAINTS"
http://amasci.com/emotor/cap1.html
HOW ARE WATTS, OHMS, AMPS, AND VOLTS RELATED?
http://amasci.com/elect/vwatt1.html
Br,
Webmug
« Last Edit: January 30, 2012, 22:14:59 pm by webmug »
Offline Hidden
« Reply #13 on: January 31, 2012, 06:18:19 am »
Newguy
"the gated signal that allows the hydrogen to pair up with opposite spin into diatomic hydrogen, allowing release of gasses"
Here is the Tech Brief reference to the statement you said Steve Meyer made:
Tech Brief page 1-7
"The liberated and moving atoms (having missing electrons) regain or capture the free floating electrons once applied voltage is switched off during pulsing operations. The liberated and electrically stabilized atom having a net electrical charge of "zero" exit the water bath for hdrogen gas utilization."
It would be cool if we could take a high speed camera and synchronize it with the cell's pulsing to see if gas is only released during the gating off time!
