Author Topic: Understanding the VIC  (Read 12535 times)
Offline Hidden
Re: Understanding the VIC
« Reply #10 on: December 07, 2011, 23:48:00 pm »
The frequency can be harmonics of the frequency used to split the water molecule. Like say if the LC circuit resonates at 5kHz, this would be like the 7th Harmonic of 320kHz.
Yea the voltage force is what causes the electrons from the SS material to be pulled off the surface and also splitting the water. To understand the cell you first need to understand antennas, waveguides and electromagnetism. Once you research this you will see that the the waveguide has to match the coil. Just like the way a radio operates.
Offline Hidden
« Reply #11 on: December 08, 2011, 04:10:12 am »
Well, it's going to be some time before I fully understand all of that. Lots of books to read :)
Thanks Don for pointing me towards that patents, I haven't read that one in a long long time.
Offline Hidden
« Reply #12 on: December 08, 2011, 04:34:19 am »
 :-XDave, you mentioned resonant action earlier.
I think the collision is a major part of all of meyers work, and the resonant action is basically a
threshold point at which dissassociation goes geometrial. Of course the resonant
action does not occur at a specific voltage, it's dependant on a number of factors like
voltage, frequency, leakage current, plate gap etc.
I think it's collision as well as the snapping action which cause disassociation.
That's  why hvdc does not produce a lot of gas. Hydrocars posted a while back
about having successfully putting hvdc across water and only producing
small amounts of gas.
Offline Hidden
« Reply #13 on: December 08, 2011, 11:06:55 am »
does that mean we want resonace at 78 ohms in L1 or 78 ohms in L2 or are those just silly questions?
Online Hidden
« Reply #14 on: December 08, 2011, 18:06:56 pm »
during current restriction you will not have electrons from the coils crossing the plates, but you will have electrons from the SS plates them self crossing through the water and this will aid in the water splitting.
You got me thinking... it would seem to me that electrons only pass through the water by being carried with an ion. As in a simple electrolysis experiment, the purer the water, the less ion content = little or no gasses.
I have attached two similar experiments for demonstration.
http://www.youtube.com/watch?v=955HMPXjgnM&feature=related
http://www.youtube.com/watch?v=XMfYHag7Liw
