Author Topic: KOH and SS resistance  (Read 982 times)
Offline Hidden
Re: KOH and SS resistance
« Reply #15 on: July 18, 2011, 02:36:17 am »
Looking over my past work in this topic I notice the resistance drop around 3 amps on all the tests.
So the 3 amps of gas production is allowing the water to flow, causing a drop in electrical resistance.
So to make our cells more efficient we need to circulate the water (more amp draw for same voltage).
Here is a chart of the last experiment and resistance.
I would consider this to be voltage dependent, however with different water, KOH and Tap, I am seeing different voltage levels(3 volts vs 70 volts) for the effect.  While current is showing a pattern, therefor allowing water movement as the gas is produced.
The chart should say "Resistance Ohms - could be associated with water flow/movement"
Not on the current graph.
Wanted to note a late edit on reply # 8 where the voltage raised 1 volt and amperage doubled.
Added Water Resistance VS Voltage, natural tap water.
« Last Edit: July 18, 2011, 06:04:28 am by warj1990 »
