I made this drawing so i can draw arrows of current direction for the conductor (copper wire) and the inductor core...
This is a way to look at how the electrical current of the series arrangement is interacting with the inductive current.. since you can draw little arrows to represent current directions in the core and the wires
You will notice that the inductance of the positive and negative choke is trying to create inductive current in opposite directions..
what happens when 2 chokes are electrically being induced in opposite directions on the same linear core setting side by side?
what happens when trying to pump electrons inductivly in opposite directions ? does the core material between the to chokes become positively charged?
if so what would happen when you switch off primary?
would electrons not implode into the spot you just removed them from.??
what happens when negative charges implode into a positive charged domain from 2 different sides?
could this be the electron bounce phenomenon?
