Author Topic: alternator setup  (Read 3154 times)
Online Hidden
Re: alternator setup
« Reply #5 on: February 03, 2008, 16:17:31 pm »
Now lets see what happens when the cell is connected.
Here below I connected the cell and checked across it with the oscope:
Now that the cell is connected the amplitude dropped to about 5volts.
I did not measured the current through the cell yet because I don’t have a meter that reads more than 10amp maximum.
The cell takes 114 seconds to fill 100ml (not bad for only 5 volts on it)
Are these results good or is there something wrong from these initial tests?
Thanks guys
hmask
Online Hidden
« Reply #6 on: February 03, 2008, 17:33:51 pm »
Now lets see what is the output from the 6pack rectifier
Here it is:
As you can see here this is the output from the 6pack. The amplitude is about 22v peak. Please note that the cell is not yet connected.
That seems normal. 22V on the output is ok
steve
Online Hidden
« Reply #7 on: February 03, 2008, 17:36:53 pm »
Thanks guys
hmask
Ok buddy,
The voltage drop is high. If you drop from 22V to 5V, means to me that perhaps your WFC is pulling too much amps?
Can you show us some pics of your wfc?
And go arrange a good ampmeter. You will need it!
Br
hydro
« Reply #8 on: February 03, 2008, 19:55:19 pm »
ok, im not sure of what you're even doing here, for one why do you have 4 wires comming from your stator going to the diodes? don't use the center wye. also check that you did hook the diodes like in the schematic.
now you have a dc output. what you need to do next is get rid of the water cell, you need to determain your polarity.
take the 2 leads comming from your rotor, now take the 2 leads comming from your diodes. Connect the leads from the rotor to the leads from your diode, Did you notice anything? if NO then switch the wires and try again.
when you notice a spark when doing this you should note what wires was connected to what when you got this spark, this will be your setup. the rotor can only hook to the stator 1 way, its up to you to find it. you may have to hold the wires together for a short periode of time, "until votage starts to take over".
if you failed with the instructions i have given you above then do it again, but this time hook 12 volt battery to your ROTOR for about 6 seconds, this will train or condition the rotor. when you have your rotor conditioned never hook it up backwards to a battery. Then repeat the steps above.
after you have confirmed that you can get sparks from the alternator setup you should have noted how all the wires go together. when you get this information then you add a mosfet "between the wire comming from the rotor where it is connected to the stator", then you regulate it with the circuit we have provided.
when you get all this connected then hook your fuel cell up.
restart the process, "Amp meters between the Rotor and Stator has been known to kill the process."
now if you have a failure, bump the 12 volt battery to the rotor, "with your setup in tact and your pwm circuit off", hold the battery to for 3 seconds.  remove the battery and power on your circuit, power it up and hope for the best.
the mosfet is touchy as well, there is a certain way, way you can install the mosfet between the stator and rotor, and i forget wich lead to connect it to.
the circuit you're looking at is the ideal, it has not been confirmed that it is the exzact way everything should be connected.
bee looking for your reply on the next test you run.
« Last Edit: February 03, 2008, 19:57:58 pm by hydrocars »
Online Hidden
« Reply #9 on: February 03, 2008, 23:28:22 pm »
hi stevie and hydro.
the 4th yellow wire is the center. it is not connected. i just used it to see the sinewaves on each phase with the oscilloscope. the cell is ok. I will post some pics as soon as possible. I am going to change the lead wires and check if the voltage drop persists, because I noticed that the leads get warm (they aren`t beefy as they look from the outside). Then I will follow the steps Hydro. but now it is time to go to sleep. gn
hmask
