Author Topic: alternator setup  (Read 3154 times)
hydro
Re: alternator setup
« Reply #10 on: February 05, 2008, 23:36:59 pm »
hydrogenmask how is your setup comming along? i cant wait to hear from you! if you are having problems then let me know.
Online Hidden
« Reply #11 on: February 06, 2008, 00:01:51 am »
no hydro. I am having a very busy week and I had to back up a little with my experimenting :-\. I will keep you informed as soon as I get back into it. By the way I am going to change the driver motor with a bigger and prittyer one. 8)
Online Hidden
« Reply #12 on: February 08, 2008, 09:34:38 am »
Hi all,
ok, I changed the driver motor to 1/2hp one -2900rpm- 8)
changed the lead wires going to the cell with a ticker one.
redone the test with 5volts on the rotor
results:
USING TAP WATER
voltage droped from 22Vpeak (without cell connected) to approx 7Vpeak (with cell connected)
changed the water to REVERSE OSMOSES (containes less contaminants)
voltage droped from 22Vpeak (without cell connected) to approx 9Vpeak (with cell connected)
Do you guys think that the cell is too much for my small car alternator?
As well I noticed that if I higher the voltage more than 6v on the rotor, the driver motor would not have enough torque to speed up the alternator. Is this normal?
Hmask
Online Hidden
« Reply #13 on: February 08, 2008, 09:38:52 am »
these are some new pics
Online Hidden
« Reply #14 on: February 08, 2008, 09:42:39 am »
the last pic is with 6v on the rotor. production increase to 45sec per 100ml (aprox 9Vpeak on the cell currnet yet to measur)
