Inductance of a multilayer coil of rectangular cross section can be computed by below formula when optimizing maximum distributed capacitance and distributed inductance to intensify Inductance Field Strength to function as a voltage multiplier in switch-off conditions , as illustrated in (710) of ~. Figure (7-10) as to VIC
Coil Assembly (580) of Figure (6-1) and, is expressed:
Where,
(L) is the inductance in microhenries
(N) is the number of turns
(A) is the mean radius in inches
(B) is the length of the coil in inches
(C) is the depth of the coil in inches
what i find interesting is that this formula does not have a variable for the relative permeability of core material.. which in turn means this formula is for a air core inductor
here is the formula from wiki
Multilayer air-core coil formula
- L = inductance (µH)
- r = mean radius of coil (in)
- l = physical length of coil winding (in)
- N = number of turns
- d = depth of coil (outer radius minus inner radius) (in)
so why would stan give a formula for air core inductor? while it seems that he implies that they are wound on a core?
he refers that vic 6-1 is an example for the multilayer coil.. 6-1 has a laminate steel core...
