This topic will be focusing on the polarity views of matter and current..
Alternating current - when a point of charge is changing course from one direction to another direction that is 180 degrees out of phase; doing so sequentially in time.
sequence is a predetermined/scaled change of phase based on time.. we call it a frequency.
my point in this topic is the most talked about alternating current is that of the electron
protons can as well alternate their direction of current. (path of projection) by the application of a external force..
I see having 3 forces and 7 styles of applications of external forces..
The forces
1- a paddle (non stationary)
2- voltage (a field)
3- light
the styles
1- paddle
2- voltage
3- light
4- paddle, voltage
5- light, voltage
6- light, paddle
7- paddle, voltage, light
3 of the primary styles of understanding
1 paddle
Something non stationary and physical like a paddle forcing the protons into motion
this style of force is on both the proton and electron to be influenced into the same direction/phase the paddle is traveling
2 voltage
Something stationary having the ability to change its potential charge within its given space " faster/less resistively" then that of its surrounding mediums. Different dielectric qualities between materials in a given space will create different characteristics in the "style" of energy transfer (current /or wave)
3 paddle and voltage
By the application of Both at the same time.. a physical force by a non stationary object (paddle) and by a electric field (a change in the surrounding potentials electrical charge)..
1- is a force that influences both electron and proton in the "same direction"
2- is a force that influences electrons and protons in "opposite directions"
3- is considered 2 variables. meaning they can be in or out of tune with each other??
there are 2 styles of generation/force happening instantaniously forcing motion in its surrounding medium. I think to tune them you need to know there natural tone they ring at physically and build the circuit to match that frequency.
i am not fully clear on lights effect (force) in a medium
As for Stan his resonant cavity was stationary and applying a strong positive field.. while restricting electrons..
I think he was not focusing on the oscillation (alternating) of the electrons as much as the protons oscillations in the water. I think he figured out how to amplify (resonate) the proton in audio range in a stationary gap. While influence the electrons in the opposite direction of protons oscillation at the same time.
