Author Topic: Dankie invents again  (Read 1467 times)
Offline Hidden
Re: Dankie invents again
« Reply #10 on: July 29, 2010, 03:37:32 am »
It deffinitly could  , but this is a linear sine amplifier , not a 98.5% efficiency pwm unit t, its really for getting maximum sine purity for small size experimenting without emi and transcient noise like pwm generated sine waves .
My suggestion is that your motor should be small as hell if you wanna use my amplifier for this . But my best suggestion is that you use a pwm vfd . If you intend to use the 3 phase  energy directly then my amplifier is by far more efficient since you are not using the "state of art method for experimenters" ( motor running alternator wich runs load ) . I think I said by now why this isnt good or efficient for experimenting .
Remember that you need center tapped primary transformer to combine both half waves into a useable sine .
With love from russia .
http://www.overunity.com/index.php?topic=7679.msg250305#msg250305
outta here .
« Last Edit: July 29, 2010, 03:54:25 am by Dankie »
Offline Hidden
« Reply #11 on: July 31, 2010, 10:48:38 am »
As I trying to figure out more about the kapanadze pulser somebody showed me the right circuit and good site with goood info .
http://www.overunity.com/index.php?topic=7679.3315
Offline Hidden
« Reply #12 on: August 21, 2010, 08:35:07 am »
Here is the pcb ill be getting from pad2pad in 10 days .
Here is is it , i got a box of components right here and am waiting for the pcb .
If this works as simmed this is gonna be a success , I can now see the move towards renewable energy . The tool for the new economy , every tent village will have one of these .
I have incorporated true groundplane starground , DIP package for all chips for easy soldering or simply snap on . run a few power wires and thats it solder some resistors capacitors and thats it .
On here is a super useful pulser , with intuitive harmonics and a manual gate jolt-like , wich can be used as the main pulse if you want to . On here is a flyback flip flop circuit also for some kapanadze , the best pulser that money can buy , mosfet and mosfet driver included , theres a P channel Mosfet here also wich can be drivenb y a multitude of possibilities incase you want a high side drive like the EEC or ion experiments .
On here are two 0-25000 pure sine generators , you can go low as 0.25 hz since all is dc coupled muahahahaha . A good AM mixer is included exactly as specified by Puharich , tuneable to the max .
On here is a dual 3 phase pure sine network from 0-25000 hz
On here is 6 channels of what I call a no transcient amplifiers , extremely durable because I use all N channel mosfets , self regulating wih feedback , very easily switchable from "AM efficiency mode" to "super stable and strong for reactive load mode" . Theres always 100% feedback with both modes . all 6 channels have been designed for over power 30 amps per channel  . This will be a fan cooled heatsink on the side amplfier . See that starground plane , now thats a real starground ground plane ,   not the crap you would get from a panasonic or sony instrument .
I am very excited since I see this as perfect for the joband made some excellent logical choices , it is better than , smaller than , unique , many times cheaper than , vs 2000+ dollars  of crap instruments and equipment wich are in reality useless since you neeed endless pre-amps , amps , differential signaling , shielding , + all these are bad for the job anyways , all this is solved with this one small yet very powerful board . This is the tool for the new economy of tinkerers , soon there will be only tinkering goin in the states , millions of oppressed tinkerers .
« Last Edit: August 21, 2010, 09:47:22 am by Dankie »
