Author Topic: 102 plates drycell  (Read 4149 times)
Online Hidden
Re: 102 plates drycell
« Reply #10 on: May 03, 2010, 22:49:11 pm »
Hi steve
i was guessing that both ways could work on avoiding the reformation, but while ionizing negatively we can fill 1 or both of the electron holes doubling the number of water molecules forming OH using more oxygen than the original from electrolysis or actually even preventing the reformation in the case we fill both holes, but if we thus ionize positively what would happen is that we could open one more holes in the oxygen atoms allowing it to bound with 3 hydrogens forming H3O witch would be actually avoid the reformation of water molecules as stan described, because for every oxygen there will be 3 hydrogens!!!
This would lead us to have the following:
For every 3 mole of water reacted or 54 grams we would have 2H3O so we are losing 1 oxygen or 16 grams. Thus we would have 38 grams in the end. 70% of the original mass
The negative way lead us to have the following:
For every 3 moles of water reacted or 54 grams we would have 6OH thus having 3 more oxygens creating water ending up with 102 grams. Almost doubling the mass!!! 188% gain in mass
I'm not sure which would work the better! Or witch would gain more energy... but steve now that you have lot of gas you can perform some tests. Try to use more than one stage being one negative other positive and so one. the last one will give you the reversed polarity you want in the end if i'm not wrong. (i read about in some patents about ion generation)
I was thinking that maybe is possible to charge the all engine! to prevent the gas from discharge... .
This would explain the noize recorded in the stan demo video
Thus we can use:
Laser energy to help the atom to get exited
High voltage
Magnetism
Electromagnetism
And we have :
Movement of the air
Think about steve
Best Regards
I tested with positive ionization of air and that didnt do anything.
The only thing i could try is to feed the HHO and air thru the ionizer, but my theory is that is doesnt make any sense and is dangerous.
HHO is already ionized when it leaves the wfc.
Online Hidden
« Reply #11 on: May 04, 2010, 04:00:04 am »
Hi steve
Did you tried to ionize positive or negatively only the air or exhaust that were entering the engine???
Regards
Online Hidden
« Reply #12 on: May 04, 2010, 09:33:20 am »
Hi steve
Regards
only the air.....
Online Hidden
« Reply #13 on: May 05, 2010, 22:15:56 pm »
Small update:
Just finisched building my powersupply for the new drycell.
I ran a powertest and it works like it should.
Also got my waterreservoir annex bubler. This one is made of SS and has 2 wateroutlets and 2 gasinputs, conform by new drycell.
My wife complains about the fact me not being available last days.....
Well. I am at home, but most of the time in my lab..hehehehehe
Anyway, it all looks great and is almost ready for a first testrun.
Sadly for this, it has to wait for a week.....
I am out  fisching for a couple of days.
The good news is that the paint can dry up nicely now....
Cu
Online Hidden
« Reply #14 on: May 22, 2010, 19:28:58 pm »
Here an update on my current build.
I had made a nice SS bubler annex reservoir for the 2 sections of wfc.
Sadly this concept didnt work. Current started to leak between the 2 sections thru the waterhoses!!!!
So, i build me 2 seperate bublers.
Here are the results from my first testrun with KOH.
This is the water that is cleaning the cell, so to speak.
Hopefully i will get more KOH for a new load of water.
102 plates and 101 cells.
At 185V by 6A its doing a 1.5 ltr HHO per 12 seconds (7.5ltr/minute)  = 95% Faraday = 6.8mmw  (1.83V per cell)
At 191V by 10A its doing a 1.5 ltr HHO per 7 seconds (13 litres/minute) = 95% Faraday = 6.7mmw (1.89V per cell)
These are not bad numbers. When the cell get more hours on running and with new water, it hopefully will do a bit better.......Target is 100%.
My setup seems to be able to do like 15 litres HHO within reasons.
« Last Edit: May 22, 2010, 19:45:18 pm by Steve »
