• May 22, 2013, 03:46:24 am
Author Topic: Water vapour injectors. How is might work.  (Read 1818 times)
Online Hidden
Re: Water vapour injectors. How is might work.
« Reply #5 on: April 02, 2010, 10:50:42 am »
Hello you all i'm coming up right now with info that anyone though before!
I solved the injector!
What happens when a conductor moves cutting a magnetic field?
A voltage is developed! in a direction 90° from the magnetic field lines and 90° from the movement!
What happen when we have water under a very high pressure and make it to pass thru a 0,40 mm diameter hole?
It will pass thru it at a very high speed!
water is not conductive thus ( the ionized gases were needed in the injector to create the conduction )
Lets say you have a 0,40 mm hole 6cm long (it will have a volume = to 7,5 ul ( the amount stan said was injecting for each injection cycle in each cylinder) accordingly to the volume of a cylinder calculation =((diameter/2)^2)*High)
Now you need to inject it in only 2ms what will be the speed of the water?
answer (6cm/0,002)*(7,5-7,4) ((volume of the tube - the amount of water to be injected) (this result is = to how many times the tube will fill per injection) well the result is almost 3000cm/sec
Now if you cut a magnetic flux of 15.000 gauss with water at this speed you will develop 1,7volts witch together with the ionized gas and a catalyzer element and resonance will actually crack the water!!!
Enjoy Freedom!
Now you just need to develop a certain pressure inside the tank, (only about 4 liters of water will be consumed in one hour thus even very high pressure will cost very low energy) and solenoids to do all the work...
What about this? 8)
after 2010 years we can again walk on water...haha
Best Regards to you all
Donations are welcome! you find link on my you tube channel
Did you know that 7,4 ul of water = 13ml of gas  h2+02 witch represents 3,33% of the 400cc cylinders meyer were using.
Yes he used positively ionized ambient gas...
He created the injectors to simplify and lower the costs
Sebos,
You just made my day!!
Thats what i like about you. You are good with these kind of calculations.
Wow. Do we make progress here or not!
In the mean time, i am currently building a big platecell of 100 plates which is wired in series, but is build in parallel stacks of 2 blocks.
Yesterday the steel front plate was ready to be painted, but slipped out of my hands and hit my feet.
Up to the hospital. 1 broken feet.........yeh....not good.
Online Hidden
« Reply #6 on: April 02, 2010, 11:05:10 am »
Finally, we have a good story / explanation on how the injectors might work....
Very very good!
Offline Hidden
« Reply #7 on: April 02, 2010, 13:49:41 pm »
 Sebosfato, have you actually ran an engine using your ideas ???  There are many of us that can not view videos, so, we quietly sit and read and wait to SEE ideas come to life. It is very difficult to picture what you have proposed.
  Is there a website or photos available for us to see ???  Thank you for sharing your ideas.  Harold
Offline Hidden
« Reply #8 on: April 02, 2010, 14:18:55 pm »
Enjoy Freedom!
What about this? 8)
I'm still skeptical, but the fact that the volume of 1l water is 1600l in HHO should account for a good pressure. Intriguing idea :) How do you want to create a magnetic field of 1,7T though? It should of course be permanent magnets as no current is needed to maintain the electric field.
Online Hidden
« Reply #9 on: April 03, 2010, 03:55:00 am »
I believe the way to create this magnetic field will be with a coil around. Once i saw a meyers drawing of the injector with the coild around it. Only once.
His drawings of the electrodes aways remind me permanent magnets, Aways orientation check it. Yesterday i was thinking about pressure and flow and big bang! I first tried some numbers, and guess what? i took a look on the canadian injector patent and the size of the holes proposed by him were the same i was guessing, He mention 125 psi pump. It was well protected... Now is free! Fortunately
The electron gun had coils too.
His work is based on MHD magneto hydro dynamics domain of plasma physics. Look for it on the mit site. Is the basics of the basics of power generation!!!!!!!! Is just like a generator works! http://ocw.mit.edu/OcwWeb/Physics/index.htm
Even the resonant cavity works with this principle.
The pressure i believe meyer used the Famous steam resonator to create or the water pump. The volume of water to displace is very small.
I didn't ran a car on water yet =( but soon is exactly what i want to do! i'm just short of money now and to design it well and make the pieces will cost a bit. But won't be too expensive for scale production hopefully!
Well good news!
Thank you all for being part of it!
Hope to finish this soon!
I think the ionizer works much the same way. not sure yet!
Best regards!
